upper ball joint
Old Dec 26, 2011 | 09:33 PM
May Bell's Avatar
May Bell
Exclamation upper ball joint
i just purchased this '79 f-250 4x4 (it's got a 6" lift, 400 small block) and found that two of the four bolts holding the upper ball joint have snapped clean in half and can be pulled up and out without any effort, barely holding my steering together on the drivers side. this truck is rolling on 35" nobbies...any advice on an easy fix would be appreciated. unfortunately i am not allowed to post pics because i'm new to this forum
Old Dec 26, 2011 | 09:37 PM
ctubutis's Avatar
ctubutis
Welcome to FTE.
Put your pics up on a hosting site (photobucket, etc.) and then use the IMG code to make them show up here.
Only paying Supporters can directly attach files to posts, the rest of us need to do as described above.
User Gallery & Picture Display Help - Ford Truck Enthusiasts Forums
Old Dec 26, 2011 | 09:48 PM
May Bell's Avatar
May Bell
ok.
Old Dec 26, 2011 | 09:52 PM
May Bell's Avatar
May Bell
the two front (closet to our view) are the two bolts that are snapped clean and fully loose. AND NOTICE THE spacer (?) in the middle of the unit, has that been added for extra support due to the 6"lift or is it stock...?
Old Dec 26, 2011 | 09:58 PM
May Bell's Avatar
May Bell
here she is
Old Dec 27, 2011 | 09:38 AM
May Bell's Avatar
May Bell
any advice on how to pull out broken bolts...
Originally Posted by ctubutis
Welcome to FTE.
Old Dec 27, 2011 | 10:16 AM
May Bell's Avatar
May Bell
i also have an oil pan leak, seems to be at the pan bolt. Should i just replace the oil pan bolt/nut? and does a leak from a front shock need to be replaced or is there a fix for that? Also my power steering lines are wet....fellas please help
Old Dec 27, 2011 | 11:00 AM
May Bell's Avatar
May Bell
'79 f-250 4x4
1-power steering lines wet
2-oil pan leak, at nut
3-front drivers side shock leak
Any advice?
1979 f-250 4x4 ranger super cab, 400 small block, 6" lift, sits on 35"s
SRBF150
27
Mar 7, 2019 03:32 PM
bullnose1985
21
May 21, 2017 08:20 PM
Growl60
Oct 17, 2011 06:56 PM
crazyredneckanyhow
Offroad & 4x4
Dec 8, 2009 11:16 AM
Violjohn78
Mar 30, 2004 10:34 PM
