Offroad & 4x4
balljoints
Old Dec 6, 2009 | 12:20 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
balljoints
So im rebuilding a dana 44 for my 79 shortbed. Ive got the new balljoints in on the drivers side but im not sure about them. Seems theres a decent gap between the dust boot and "c" on the uppers. Heres some pics. Maybe im just over concerned. Theres is plenty of space where the pin goes in the stud. And its well above the castle nut.
Lower is tight
Old Dec 6, 2009 | 06:47 PM
rebocardo's Avatar
rebocardo
That last picture it looks like the ball joint is in crooked and not seated all the way down. You can see the gap and the relief cut into the knuckle where it is suppose to seat.
Old Dec 6, 2009 | 08:41 PM
crazyredneckanyhow
Hmmm. You are correct. I looked at it and the snap ring is tight on the other side but i can see a little splines on the inside. Ill pull the knuckle off tomorrow and try to press it in more. Think thats the prob? Seems like the impact would take care of that. Also if i press the bj in more then there will be a gap between the bottom of the knuckle and the snap ring. Is that a problem?
Old Dec 8, 2009 | 02:24 AM
rebocardo's Avatar
rebocardo
Actually, makes the problem worse.
What I would do (if having a problem) is cool the ball joint in my refrigerator overnight (not freezer) and put the knuckle in the oven for 250 degrees for an hour and then press them together with anti-seize on the ball joint. This is where having access to a real press with plates comes in handy.
The clip is a safety feature to prevent total loss of steering, the press fit is actually doing the work. The joint has to be fulled seated, otherwise it may pop out and may effect alignment. When it is fully seated, the knuckle actually expands and grips the ball joint even tighter. One of those yield to break ratio things. One of the reasons kingpins are popular :-)
If you can, make sure the splines do not go into a previous splined groove. If it was me, I would junk the ball joint and start fresh with a new one. Kind of like messing up a UJ cap, the hassle of doing it over by the side of the road or in the woods over shadows the cost of a new part.
BTW: Not ragging on your choice, I have a ball joint front end myself. We live with what we have.
Old Dec 8, 2009 | 11:16 AM
crazyredneckanyhow
See the funny thing is that the BJ are splined but the knuckle is not. I can get a new joint no prob. Ill try that. BTW its no biggy about kinpins and 60s. I have a 60 for my other project. Im just doin this on the cheap. Itll be open so im sure itll last awhile.
izzo
Sep 27, 2015 11:53 PM
down2earth
36
Sep 6, 2015 01:35 PM
CaptainIPSC
37
Apr 5, 2015 09:41 AM
crazyredneckanyhow
45
Dec 8, 2014 01:46 PM
fordredfire
User Gallery & Picture Display
Jun 10, 2011 09:25 PM
