looking for vin# info
F10DK717594
also had this on the plate...
WB color model body trans axle dso
129 m f100 e81 A 08 63
any help would be appreciated.
M = Wimbledon White color. F100 = 5000 pound GVW half ton truck.
E81 = Cusom Cab body with red crush vinyl and red ladder pattern woven plastic interior. A = three speed manual light duty transmission. 08 = 3.50 gear ratio in a Ford 9 inch non-limited slip differential. You left out Max GVW which is 5000 pounds and certified net HP which is 172 at 4000 rpms. The District Sales Office which ordered your truck was Memphis (63) and it was not a special order. Hope you enjoy your new truck!
one other question. i was going to get rear disc brakes for it from summit. but they want to know if its a big or small bearing 9 inch. how can you tell the difference?
got a link to work but cant figure out how to do a picture directly to the forum. oh well
But anything can be under it after fifty years.
What brand disk kit were you contemplating. Be aware Wilwood nor SSBC have discs in the 5 on 5.5 truck pattern.
Open a Photobucket account and copy/paste pictures. much easier.
Garbz
August 1965 serial number range for model year 1966: 732,000-745,999.
or large bearing new style.
No such thing as old style or new style large bearing. 1961/86 F100/150: There is only one large 9" axle bearing, but there are two other 9" axle bearings used in F100/150's.1957/60 F100 9's use the medium duty axle bearing (B7A-1225-A / Stamped w/BIN: 2-3538).
1961/67 F100 9's use the large bearing, as do some 1968/72's.
Some 1968/72 F100 9's have 31 spline axleshafts and a 9 3/8" ring gear. Only 5 parts are the same as a 9: One pinion bearing and cup, housing gasket, pinion seal, pilot bearing retainer.
EVERYTHING else is different including the axle bearings!
1973 F100 9's have the large axle bearing as do some 1974/79 F100/150's.
Some 1974/79 F100/150 9's have an axle bearing/seal combination (D4AZ-1225-A / Stamped w/BIN: U-399-A). There's no way to know until the axle is pulled.
1980/86 F100/150 9's have the large bearing.
D8AZ-1225-C (replaced C9AZ-1225-A & C1SZ-1225-A) .. Large Axle Bearing.
Large axle bearing could be stamped w/any of the following BIN's: F-208-HL or 88128 or 208 or FPP or F208AKK
BIN: Bearing Industry Number: What autoparts stores, bearing suppliers go by.
Garbz
No such thing as old style or new style large bearing. 1961/86 F100/150: There is only one large 9" axle bearing, but there are two other axle bearings.1957/60 F100 9's use the medium duty axle bearing (B7A-1225-A / Stamped w/BIN: 2-3538 / 1961/67 F100 9's use the large bearing, as do some 1968/72's.
Some 1968/72 9's have 31 spline axleshafts and a 9 3/8" ring gear. Only 5 parts are the same as a 9: One pinion bearing and cup, housing gasket, pinion seal, pilot bearing retainer.
Some 1974/79 9's have an axle bearing/seal combination. There's no way to know until the axle is pulled.
Large axle bearing stamped with BIN: F-208-HL or 88128 or 208 or FPP or F208AKK
BIN: Bearing Industry Number: What autoparts stores, bearing supplier go by.
AXLE code: 08 = Ford 9" Rear Axle / 3.50-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity / 28 spline axleshafts / LARGE axle bearings.
But, 47 years have passed by, so who knows if the rear axle is the original...or not?
And btw: A = Ford type 3.03 Medium Duty 3 Speed Manual all Syncromesh Transmission. The Light Duty 3.03 was only used w/the 240 I-6.
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
