Using AE to diagnose individual modules?
Old Dec 24, 2011 | 06:17 PM
rbsample's Avatar
rbsample
I got my AE a while ago but haven't messed with it much yet.
I haven't been able to put my truck into 4 wheel drive and have been chasing down the issue for months now, suspecting the 4x4 shift module. Well today it decided to shift into 4 high by itself while I was driving down the road!!! I am blaming this on a possible 4X4 shift module issue since everything else on the truck checks out.
I put the AE on it and got 3 P codes transfer case something or other. Under that it says "module - manufacturer specific".
Did my AE get those codes from the 4X4 shift module or is there a way to specifically diagnose the module itself?
I wanted to call Clay so bad and pick his brain but didn't want to bother him on Christmas Eve.
Old Dec 24, 2011 | 06:48 PM
woodnthings's Avatar
woodnthings
What codes did you get? That is all you really need to know. All the modules are manufacture specific modules, that is a standard thing on our trucks.
You can get into the various modules in the Vehicle menu. You can choose them from there. I do not believe there is a specific one for the 4x4 Module though. You should be able to diagnose to a certain extent from the ABS & enhanced Powertrain Modules.
You should be able to look at this video I did to show basic navigation of AE.
Autoenginuity Video - YouTube
Old Dec 25, 2011 | 12:25 AM
rbsample's Avatar
rbsample
I got 5 codes;
P1876 Transmission Transfer Case 2-Wheel Drive Solenoid Circuit Failure
P1865 Transmission Transfer Case Contact Plate Power Short To Ground
P1820 Transmission Transfer Case Clockwise Shift Relay Coil Circuit Failure
Also a U1242 code, something about a SCP?
My 5th code is the ignition key code that I get because I disconnected the wire for the door chime.
I can run out tomorrow morning again and get the description of the last 2 codes if you think it is important?
Thanks for the help!
broken wire
1983 - 2012 Ranger & B-Series
Jan 19, 2012 11:42 AM
dcaddi2
Oct 4, 2009 07:54 PM
Benny2002
Jul 24, 2007 06:22 PM
sbond
1978 - 1996 Big Bronco
Jun 13, 2003 11:22 PM
