Diablo flip chip and reprogramming for tire swap.
??? Is the wds likte the old Rotunda NGS system where it will scan the truck while driving? Or is it one of those new $10,000+++ machines that is stationary?
Just askiin , because I know that the old ngs would tell you and let you do alot.
Yes, I have a Diablo flip chip that was programmed for stock tires. I need to reprogram the pcm to get the correct speedo accuracy after adding larger tires. I should be able to do this if my chip is in the stock position. Does anyone agree, or should I call Diablo?
DictatorDanny
Computer Chips & Tuners
01-23-2005 05:29 PM
2003, 2008, 73, chip, diablo, f250, flip, performance, postions, reprogrammed, reprogramming, revolution, swap, switch, truck
