Coolant test not needed anymore?
Old Jan 7, 2012 | 02:57 PM
  #31
cford716's Avatar
cford716
Originally Posted by JReinert
The test kit that ford uses actually tells you to take a sample from the res. It supplies you with a syringe and tube to suck it out of there. This is the info that came with the rotunda kit. Hope this helps farmerdave. I am pretty sure that there is circulation thru the res.
That's what it looked like he was using. Thanks.
Old Jan 22, 2012 | 02:50 PM
  #32
RedneckTrucker's Avatar
RedneckTrucker
Hey folks - read the string but the most important answer was missing - "how do I reset the monitor so the damn message stops popping up when I start the truck". Thanks in advance for the help.
Old Jan 22, 2012 | 09:13 PM
  #33
Painted Horse's Avatar
Painted Horse
Go to the coolant screen in your command center and press and hold the OK button on your steering wheel. Just like resetting your tripometer.
Old Jan 22, 2012 | 09:18 PM
  #34
Painted Horse
Originally Posted by kereams
Thanks. So does the BC-8 increase nitrates in the system whereas the VC-12 decreases it? Sounds like the nitrates are the issue. Doing a search for VC-8 in this forum did not yield any specific answer to the actual compatibility or ill effects.
I will have the dealership flush and fill with fresh VC-3.
Sorry, I've been on the road for most of Jan. The VC-8 does increase the Nitrates. Thats what the older coolants needed to have revitilized. The test strips you use to test are looking for any Nitrates in the coolant. If you fail the nitrate test, you need to flush and refill. Hence by adding the VC-8 to your coolant, It will now test positive for nitrates and need to be replaced.
I assume you have resolved this with your dealer. What did they do for you. They should have flushed and refilled your coolant system since it was their mistake.
Old Jan 22, 2012 | 09:33 PM
  #35
kereams's Avatar
kereams
Yes sir, I took it back the next Monday and the did a flush and fill with the proper coolant. They felt quite bad about it and took good care of me. I have it in writing that the truck got 500 miles on it with the VC-8 in it and that the flushed and filled it. I feel covered if something ever comes up.
Thank you.
Old Jan 27, 2012 | 01:29 PM
  #36
bobsplus's Avatar
bobsplus
Mine came on at 13k and then at 32k, just had checked at dealer for free....no issues, the antifreeze is orange with a green tint this is normal....as we found out at dealer, that whole story is under a seperate thread
pony
Modular V8 (4.6L, 5.4L)
Feb 21, 2014 06:05 PM
TPL33
Feb 17, 2013 07:14 PM
enduringexplorer
Mar 7, 2005 08:28 PM
RayHell
Apr 29, 2003 07:57 PM
Ghostrider304
Jan 27, 2003 10:01 AM
