Sponsored by: Real Truck
Transmission Problem......? Need Help
Old Dec 20, 2011 | 06:56 PM
jstanley's Avatar
jstanley
I have a 2000 F350 Crew Cab with a V10, it has 156,000 miles on it. This has been a great truck, yesterday the transmission started shuttering between 40-50mph. It seems to do it most when you just maintaining speeed between 40-50 ,and if you accelerate it will go away. I had my mechanic run it for codes and it came back with a P1711 code. After looking into that it comes back as a Transmission Fluid Temperature Sensor? Anyone have any experience with this issue?
At the recommendation of my mechanic friend I added a shot of Dr. Tranny into it, it seems to have helped a little....but will still shutter occasionaly.
I had the transmission flushed about 40,000 miles ago.
Can this sensor just be replaced or is it part of a large piece in the tranny? Would it be possible that a new transmission flush would take care of the issue?
Thanks in advance for any experiences and advise.
Old Dec 20, 2011 | 08:41 PM
doccamel2000's Avatar
doccamel2000
if i remember right the service int. is 30,000 so it wouldn't hurt to change the fluid and filter anyway. as for the sensor, wait for the smart people to chime in.
Old Dec 21, 2011 | 07:24 AM
senix's Avatar
senix
I would bet with 156K you have a larger issue looming. I had that type of shudder once on a tranny and within about 10K it was time for a rebuild.
flushing may prolong it but I'd personally start saving a few bucks for the rebuild.
Just my thoughts.
Old Dec 21, 2011 | 07:32 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The temp sensor is part of the solenoid body. That code doesn't mean the sensor is bad, it means the trans was either too hot or too cold when the codes were read.
Most likely you problem is an ignition coil or spark plug.
Old Dec 21, 2011 | 11:35 AM
jstanley's Avatar
jstanley
The ignition coil was the first thing I thought of, but when the mechanic ran the codes there were no misfires in the log. Should the truck be running during this test?
I live up here in northern Maine and the temperature has fallen recently to near single digits, and this is when the problems started. What is the likely solution to this if not an iginition issue? I want to get this fixed, ut do not want to replace parts if they are not going to solve the problem.
Thanks
Old Dec 21, 2011 | 09:31 PM
Mark Kovalsky
There isn't one.
I had a 2002 V10. It did exactly what yours is, and it didn't set any misfire codes and the counter didn't go up, either.
I changed all the coils and plugs and the problem went away.
Old Dec 21, 2011 | 09:34 PM
Beatdown Z's Avatar
Beatdown Z
Subsribed. My 98 E250 started doing the same exact thing, shuddering at 40-50 mph with light throttle.
Coskid
2004 - 2008 F150
Jan 29, 2018 12:54 PM
Pinggolfer
1997 - 2003 F150
Sep 27, 2011 11:34 PM
taluslowend
Jul 16, 2011 02:49 AM
glennn
Oct 31, 2006 05:52 PM
lossscause
Sep 21, 2006 12:17 PM
