Code 0712, 1783 ?
Old Sep 21, 2006 | 11:42 AM
lossscause's Avatar
lossscause
Code 0712, 1783 ?
97 F350 PSD 4X4 118K E4OD
Just got these codes, could it be the sensor only? the tranny never slips and ive never had any problems out of it.
Dont want to replace parts for the heck of it either. . .
BTW, where is that dang sensor and what do you gotta do to fix it?
Old Sep 21, 2006 | 12:17 PM
Cuda_jim's Avatar
Cuda_jim
Trans fluid level OK? Could be foaming if it's old or over full.
You might want to check the tranny connectors. Unplug them and look for damaged, corroded terminals. They have been known to just come partially unplugged.
The transmission fluid temperature sensor is located on the solenoid body assembly in the transmission sump.
