c6 shifting troubles
Old Dec 19, 2011 | 09:15 PM
ford4ever_2003's Avatar
ford4ever_2003
i have a 77 f150 shortbed 4x4 i just got done redoing rebuild the 400. the problem is the tranny now. if you shift it manually it works good till you get to 3rd then it slips for a little bit. but it wont shift very well if its in drive. i was wondering if it was due to the truck sitting for the last 7-8 years not running and it just needs to be driven a little bit? or if i have to find a differentone or get it rebuilt
Old Dec 19, 2011 | 09:53 PM
RWENUTS's Avatar
RWENUTS
Put in a new vacuum modulator or check the setting on the one in there. Could be vac hose fell off too or not hooked up.
Old Dec 20, 2011 | 08:06 AM
Rich Halsey's Avatar
Rich Halsey
My vacuum line came off and did the exact same thing your describing.
Old Dec 20, 2011 | 08:55 AM
jim collins's Avatar
jim collins
My c/6 sat around about 6 years and gave the same problem. New one fixed it. They never had the correct one in stock so i got one with a different color of stripe on it. It turned out to be better as i had changed rear gear ratios and it made it shift better than the old one did before it quit. But if it shifted correct before ,then i would recommend getting one just like whats in it. I think there are about three or more of them and you can adjust them ,at least the ones i have used you can.
Old Dec 20, 2011 | 06:52 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Yes, start with a modulator. When yoou pull it out some oil will run out. I started parking my trucks on a steep hill or jacking up the rear end and doing it then to avoid the exxon valdez coming through. If that doesn't fix it, i would recommend a fluid change to get the valve body De-gunked as much as possible. A modulator would be cheaper and easier.
I prefer the ones with the adjustment inside. those you can adjust and tune and set it where you like it.
Old Dec 20, 2011 | 07:21 PM
Action4478's Avatar
Action4478
Make sure the shift down linkage is working properly ...After you change the modulator ...
Old Dec 20, 2011 | 11:52 PM
jsutton's Avatar
jsutton
My C4 was doing the same thing about a month ago, I followed the suggestions, changed the modulator and adjusted the intermediate band, but it didn't help at all. And F250 Warhorse isn't exaggerating about the Exxon valdez when you take out the modulator either so be prepared. Anyway it didn't help mine at all, I ened up having to pull the transmission and rebuild it, turned out my clutches were toast.
Hopefully just replacing the modulator will work for you though.
You might also want to drop the pan and change the filter along with the fluid change that was suggested.
Old Dec 21, 2011 | 05:49 AM
ford4ever_2003
i think im going to try modulator and change the fluild my pan leaks anyways
Old Dec 21, 2011 | 12:02 PM
F-250 WARHORSE
that is where I would start. jsutton is on to something too. wore clutches will act as described if it has a lot of miles or has been overheated. I would do the modulator and fluid both probably. On the leaking pan, those are prone to leaking but they have been overtightened and distorted in mine. I like to put a good straight edge all over on the pan and try to get it back to square again with a mallet. Sometimes a block of wood helps too. good luck
Old Dec 21, 2011 | 02:05 PM
ford4ever_2003
I was also wondering how hard it would be to put a shift kit in it while I had it open I've never done one before
Old Dec 21, 2011 | 02:12 PM
jsutton's Avatar
jsutton
It wouldn't be too hard, I should have put one in mine especially since I had it out and apart but didn't because I wasn't sure if my rebuild was even gonna work right since it was my first attempt. LOL
Old Dec 21, 2011 | 04:51 PM
ford4ever_2003
i cleaned off the modulator and i couldnt find anywhere on the outside of it where there is a color marking i dont know if its inside it or not bot what color of one should i get
Old Dec 21, 2011 | 04:53 PM
jsutton's Avatar
jsutton
Most common is the green stripe. I think people like the black stripe too, IIRC the black stripe makes harder shifts, but not 100% certain on that part.
EDIT: That may just pertain to a C4, I'm sure someone else will be along shortly.
alchemist1
Oct 24, 2014 02:51 PM
Byron Sanders
15
Sep 23, 2012 12:43 AM
stoshmolcany
Jul 3, 2011 11:48 AM
jadmt
Feb 10, 2008 10:42 AM
Fordbronco69
Nov 30, 2005 12:42 AM
