Which fuel pressure regulator?
Old Dec 16, 2011 | 03:22 PM
NW 150's Avatar
NW 150
Hi I was thinking about getting a fuel pressure regulator for my F100, because I think too much pressure is occurring and causing problems. (The clear filter by the carb is full to the point where it's kinda bubbling a bit, not much though).
Can anyone suggest a regulator from the summit racing website? The cheapest one is what I'm looking for.
If not at least tell me which one to use? I know I want to be able to set the psi at 5.5
Old Dec 16, 2011 | 03:25 PM
NW 150's Avatar
NW 150
How about this?
Mr. Gasket 9710 - Mr. Gasket Fuel Pressure Regulators - Overview - SummitRacing.com
Old Dec 16, 2011 | 04:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
As original, the metal (not clear plastic) fuel filter threads onto the front of the carb, has a nipple on the t'other end for the neoprene fuel hose to clamp onto.
Some peeps don't realize that this is the fuel filter, so they install an inline fuel filter.
The aft axle and mid-ship fuel tanks have a plastic meshed filter screen that slides onto the sending units pickup tubes.
When was the last time one a these puppies was changed?
Old Dec 16, 2011 | 04:39 PM
NW 150's Avatar
NW 150
Sorry I also forgot to mention the carb is an edel 600cfm. I've changed the clear plastic one I have a few inches before the carb last year. I've changed the filter that's on the fuel pump itself in april-mayish, but have never noticed another filter between that and the tank. Also when I say the filter is bubbling I mean that it's expanding because of the amount of gas in it.
Old Dec 16, 2011 | 04:44 PM
Rogue_Wulff's Avatar
Rogue_Wulff
I hate these things. They are prone to leaking, and tend be a bit restrictive when you start using the loud pedal heavily.
A much better choice:
Holley 12-803 - Holley Fuel Pressure Regulators - Overview - SummitRacing.com
Old Dec 16, 2011 | 04:48 PM
NW 150's Avatar
NW 150
I liked that one as well but it didn't have any fittings that came with it. As dumb as it may sound, where can I get those?
Old Dec 16, 2011 | 04:50 PM
Rogue_Wulff
Parts store or hardware store. Thread size is listed as 3/8" NPT, and the fuel line would be for whichever size you have on the truck.
Old Dec 16, 2011 | 04:58 PM
NW 150's Avatar
NW 150
Thanks for the help!
Old Dec 16, 2011 | 05:06 PM
Rogue_Wulff
NP. BTW, that Holley unit is rebuildable, if the need ever arises.....
Old Dec 16, 2011 | 05:15 PM
montana_highboy's Avatar
montana_highboy
I've been running that same Mr. Gasket FPR for 8+ years without issue, bought it at my local NAPA for 20 bucks.
Old Dec 16, 2011 | 05:34 PM
NW 150's Avatar
NW 150
It wouldn't affect WOT being limited to 6psi even though it'd be set at 5.5? I don't really know much about the gas flow and what not for carbs, just that they need a certain psi and how to hook them up.
Old Dec 16, 2011 | 05:41 PM
montana_highboy
I have mine set at 5psi and i haven't had any fuel starvation problems at higher rpms, but my truck rarely sees anything north of 3,500 rpms.
Old Dec 16, 2011 | 05:47 PM
NW 150's Avatar
NW 150
Okay so I might just go with that one then. And neither does mine. It's seen about 4200 for a second once.
Old Dec 16, 2011 | 10:32 PM
co425's Avatar
co425
The mr gasket one works fine. But if you think your fuel pump is due for replacement elbrock fuel pumps are internally regulated. Expensive but no extra b.s. to deal with.
Old Dec 17, 2011 | 07:05 AM
Blue and White's Avatar
Blue and White
I know the Holley unit is a good one. Mr Gasket is probably OK but I have no reference.
If you are running a stock style fuel pump, I'm a little surprised pressure is so high. There are millions of them in service with carbs and no added regulator. It should be internally regulated. Maybe the valve is stuck or it is defective? If you are running a high performance or electric fuel pump, i understand why the regulator is needed.
A replacement stock style fuel pump may be the simplest and lowest cost solution.
