When Should I replace my batteries
Old Dec 18, 2011 | 11:13 PM
1L243's Avatar
1L243
I have two maintenance free Pacific Power batteries. They were installed 6 years ago when I purchased the truck when it had 27k on it. It now has
130k. I am not having any battery problems, truck starts fine. When should I think about changing them?
Old Dec 18, 2011 | 11:16 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
When they start giving you problems.
Old Dec 18, 2011 | 11:46 PM
kawcrasher's Avatar
kawcrasher
Great answer. I've seen batteries die in 3 months and my 95 F150 had the same battery in it until right around 09.
Old Dec 19, 2011 | 12:40 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Batteries don't generally go bad all of a sudden. They usually give you warning. That's when you should replace them.
Old Dec 19, 2011 | 12:44 AM
big poppa's Avatar
big poppa
A inexpensive volt meter gauge helps out too, for impending problems that is. My stock Motorcrafts lasted me 6 years then as my batts. started to go they took out my alt.
Old Dec 19, 2011 | 05:33 AM
hammer65's Avatar
hammer65
Just replaced mine Saturday. One had gone bad. Volt meter was showing 12.xxx, and engine was starting at temps in the low 30.s, but it was turning over slow and dying fast.
My batteries were dated 04/07.
I guess what I am wanting to say, is have them load tested, and be sure and unhook one of them and test seperatly. It sure made a difference in cranking and starting.
Old Dec 19, 2011 | 06:16 AM
Tugly's Avatar
Tugly
If your rig is jumping to life in the morning, I doubt you'd even ask. If you're asking the question because something happened or the cranking sounds wimpy, new batteries are in order.
Old Dec 19, 2011 | 11:16 AM
Brother Les's Avatar
Brother Les
Get a plug in the dash volt meter (Wallyworld 15.00). it will tell you the starting voltage, then the draw down when the GPR stars up and when started the voltage coming out of the Alternator. It takes a lot of worries on what is going on in the voltage system.
dmoody82
Sep 2, 2011 05:26 PM
Mulepick
Jul 31, 2011 04:30 PM
JE917
Jul 10, 2010 07:27 PM
scottie2hottie
Electrical Systems/Wiring
Jun 18, 2008 07:24 AM
AndCam
Jul 14, 2004 06:03 PM
