Battery replacement?
Old Jul 14, 2004 | 02:52 PM
AndCam's Avatar
AndCam
Question Battery replacement?
I just got a call from where my 2001 F-350 PSD is being serviced and they say the batteries need replacement. One has 450 cranking amps, and the other 750. 750 is what they are supposed to be at, but they recommend replacing both at the same time. It doesn't make sense to me. Is that recommendation standard for correct maintenance, or for higher sales? Also, I'm not having any problems starting, do I need to replace the lower one, or can I wait until I start having problems?
Thanks!
Old Jul 14, 2004 | 05:24 PM
momalle1's Avatar
momalle1
You should replace both at the same time. You may get away without doing it, but the recommended setup for dual batteries is to do both at the same time.
Old Jul 14, 2004 | 05:38 PM
prcrboy's Avatar
prcrboy
if you don't, the other battery can in theroy cause the other to go bad.
Old Jul 14, 2004 | 06:03 PM
87 XLT's Avatar
87 XLT
Just go to Costco, buy 2 batteries & put them in yourself.
