cutting out???
Old Dec 18, 2011 | 08:04 PM
bryanlindborg600's Avatar
bryanlindborg600
cutting out???
i have an issue with cutting out/sputtering... not sure how to describe it, but it is most obvious at highway speeds doing 65+ if i go to floor it or even apply steady pressure to the throttle it acts as if i'm not getting proper fuel or oil.. its kinda a steady choking keeps going but no check engine light comes up or anything.... during regular driving through town if i am to step on it i get a slight delay/heck up before it goes. i have a dp tuner chip and if i put it in stock mode i do not get the symptoms i am talking about above. so i am thinking that it is the hpop? just a thought though any help would be great as i would prefer to buy the the t500 before the prices go up if that turns out to be the problem
Thanks
Bryan
Old Dec 18, 2011 | 08:48 PM
fordpride's Avatar
fordpride
Check the fuel pressure under a load
Old Dec 18, 2011 | 09:18 PM
bryanlindborg600
Whats the best way of going about testing fuel Pressure under a load? You think I could be fuel pump related? I thought that as well... I tend to assume the worst that's why I suggested hpop..
Thanks
Old Dec 22, 2011 | 06:39 PM
bass-n-fire's Avatar
bass-n-fire
I have been having the exact same problem. I have no programmer, therefore I know it isn't that. I have replaced the CPS, replaced the fuel filter, cleaned the FPR screen. I just checked the ohms for the injectors and everything was within range. I am at a total loss. I will be keeping tabs to see what else I can check.
Old Apr 12, 2012 | 01:44 PM
superduty4x4's Avatar
superduty4x4
Did you ever get this sorted out?
Old Apr 12, 2012 | 02:02 PM
bryanlindborg600
Not yet, pretty bad i know...but its not noticeable unless I'm really getting on it at high speed so it doesn't occur often but now that you've brought up my lack maintenance i am going to look further into it... when i get some time, I'm saving for stage 1s and t500 now, i just have a feeling its prolly hpop... ill look into fuel pressure and other things, but it doesn't do it in my stock mode so that's why I'm thinking oil....
Thanks for the kick in the butt to work on this...lol
Trapping
Apr 26, 2011 08:04 PM
bulla
154
Aug 30, 2010 07:37 AM
1999SuperDutyStroke
15
Jul 10, 2010 10:27 PM
fordpride
Jul 2, 2010 10:46 PM
reberhardt
Jul 13, 2002 01:53 PM
