Sponsored by: Real Truck
Tranny gears
Old Dec 18, 2011 | 05:17 PM
66shadow's Avatar
66shadow
Tranny gears
I have a stock tranny for a f350 but have 37's on it and need to change the stock gears. What is a good set up for towing a large trailer. The tranny is a 4r100/e40d. Any suggestions?
Old Dec 18, 2011 | 07:26 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You want to change the gears in the transmission? That's essentially impossible. I think you want to change the differential gears.
Old Dec 18, 2011 | 07:40 PM
Bigpipes 35's Avatar
Bigpipes 35
As Mark stated you would need to change your front and rear axle gears, and with that size tire I would say 4.56 would be the minimum you would want to go..
Old Jan 8, 2012 | 05:12 PM
66shadow's Avatar
66shadow
another thing...I have been having problems with it going into OD. Is this due to the stock Ring and Pinion gears...and if so I was also told to go with 4.88 gears front and rear...
Old Jan 8, 2012 | 08:48 PM
Bigpipes 35
Yes and Yes ...
andyman91
Feb 3, 2010 05:53 PM
hellmjama
Feb 25, 2007 06:33 PM
MattSelph
1978 - 1996 Big Bronco
Jul 3, 2004 07:13 PM
95xltmud
Feb 25, 2001 03:22 PM
