which gears
Old Feb 25, 2007 | 06:15 PM
hellmjama's Avatar
hellmjama
which gears
i have a 1995 ford f-150 i put a 9 in rear end in it and i would like to put 35" tires which gears would be right for the job, and also would i need a differrent carrier
Old Feb 25, 2007 | 06:33 PM
Thomasm67's Avatar
Thomasm67
Is it 2wd or 4wd? and no you won't just pull the 3rd member change your gears i'd go for at least 4.10's and since your putting 35's on your gonna have to change the gears in the D44 up front to match the gears in the 9 you can buy another 3rd member with any gears you might need to run 35's.
