Need help! Carb spring
Old Dec 18, 2011 | 04:12 PM
Gf2501's Avatar
Gf2501
Guys,
I am in the middle of replacing the ignition coils in my 1971 f250 with a 390 engine.
As I loosen the bracket to remove the coil, one spring to return the carb throttle came loose as well as a bracket that seems to come from the back of the engine to attached somewhere in the carburetor as well.
Does anyone have any close up picture of their carb installed that would show the proper location of this spring and bracket?
Thank you
Old Dec 18, 2011 | 07:24 PM
HIO Silver's Avatar
HIO Silver
Multiple pics on this thread including options to delete the funky bell crank mounted on the back of the intake manifold:
https://www.ford-trucks.com/forums/1...250-352-a.html
There is sometimes another spring and bracket mounted near the coil. The short tang of the spring hooks to the bracket, the coils locate on the other side of the vertical "wall" of the bracket, and the other side of the spring hooks onto the small hole on the idle stop bracket on the carb.
lamoz
Aug 2, 2017 02:05 PM
beartracks
WTB - Parts & other
Mar 15, 2017 01:42 PM
beartracks
Mar 15, 2017 10:21 AM
nutinbutford
May 17, 2007 10:30 PM
justin04
Jul 29, 2004 05:01 PM
