Steps/ rock sliders!
Old Dec 19, 2011 | 08:59 PM
Krisx125's Avatar
Krisx125
See i like those! but im trying to figure out what id do for the step part. Im kinda limited on metal fab tools...Dont think i could make it flat enough to stand on.
Old Dec 20, 2011 | 09:14 AM
strokin'_tatsch's Avatar
strokin'_tatsch
Originally Posted by BIGRED 7.3L
My bed hits mine when it flexes. Mine are N-Fab and I plan to build some drop brackets to lower them just an inch. They mount to the truck not to the frame. If you build them you could try to mount to frame but I don't think it will add much stiffening.
I planned on doing 3 mounting points straight to the frame for each slider. I figured just a square piece of 3/8" plate bolted to the frame with 4 bolts then the slider mount welded to that might stiffen it up a little, but maybe not enough to keep from hitting the bed. I could even use some angle iron and do 2 bolts in the bottom of the frame and 2 in the side of the frame with the slider mount welded to that... I may have to figure out a way to stiffen the frame up a bit...
Old Dec 20, 2011 | 09:26 AM
Jeepincj7's Avatar
Jeepincj7
Drilling the frame IMHO is a no-no on a frame that twists the way this does. It will leverage the holes and could crack an already weak frame IMO.
They need to be welded on with fish mouth plates. Vertical welds are bad on a heavy use truck like this too. We use Diamond shaped plates on our Toyotas when we weld to the frame. Diagonal welds are much better.
Old Dec 20, 2011 | 10:19 AM
strokin'_tatsch
Good to know. So, if done the way you do them, do you think they would stiffen the frame enough to keep the bed from hitting the sliders or no? Just wondering if I can tuck them up tight below the bed like in the pics or if I'll end up having to drop the sliders to keep them from hitting.
Old Dec 20, 2011 | 12:51 PM
Jeepincj7's Avatar
Jeepincj7
I would leave around 1/2" of clearance at the body, and it should be fine. The bed will flex with the frame, and since the slider is tied to the frame, if shouldn't deflect or crush the body mount enough to allow contact. .
Old Jan 7, 2013 | 05:45 AM
RadnyB999's Avatar
RadnyB999
I've seen a design which uses a receiver hitch welded to the backside/underside of the slider. Then a removable step, that fits into the receiver. This step protrudes out further than the rock slider, and is lower too. And removable, so that when 4x4in' won't get hung up on big rocks.
NMB2
Aug 14, 2012 09:18 AM
Stephen67
28
Aug 4, 2012 10:27 PM
07xpyebel
17
Apr 14, 2012 07:07 AM
ppav
Jun 12, 2011 10:10 AM
SuperSnake
North Carolina Chapter
Mar 8, 2009 09:38 PM
