Open Headers?
Old Dec 17, 2011 | 11:32 PM
SuperDuty93's Avatar
SuperDuty93
Open Headers?
[SIZE=3][FONT=Calibri]So today I decided to take the exhaust off and see what open headers sound like. Mine sound sick! I have a friend who runs open headers during the summer months due to the warmer air. He was telling me if I do open headers, every time I turn the engine off, I need to stuff a rag or towel or something to block cold air from going up into the block. Is this true? What would happen if cold air goes up the headers after I have been driving?
Old Dec 17, 2011 | 11:37 PM
bamaf150's Avatar
bamaf150
You can crack a valve or so I have heard. They are red hot when running, you shut it down and the cold air rushs in and they crack but I dont think this will happen with headers, only a really short system, such as exhaust manifold only. This is what I've heard, if true, I doubt you could get the rags in quick enough anyway.
Old Dec 17, 2011 | 11:38 PM
sled250's Avatar
sled250
The cold air could cause something in the head to warp
Old Dec 17, 2011 | 11:47 PM
SuperDuty93
Ok not getting the rags in fast enough is what i was thinking. So its almost pointless to try and most likely burn yourself. What i was thinking though is putting short 12" drop off. So have about a foot of 3" pipe come off the collecters and then nose down so the exaust is straight down towards the ground. Kinda harder to let air in. Idk. I really want that super cool deep throaty sound mine make when they are open but dont need to mess up my engine
Old Dec 18, 2011 | 12:02 AM
fmc400's Avatar
fmc400
MSEE
That's the first thing that crossed my mind when reading this thread.
Old Dec 18, 2011 | 12:07 AM
bamaf150's Avatar
bamaf150
Its not going to do it with headers I feel sure. When I was in high school guys used to uncap their headers all the time. We used to run 12'' straight pipes on 180 lycoming aircraft engines on airboats as well. The headers should be plenty long enough to heat the air coming in until the valves cool just a bit. FWIW open headers should only be run on really bad *** trucks IMO, like someone said in the LOWD thread, if its gonna be loud as hell, it better be fast....
Old Dec 18, 2011 | 12:11 AM
montana_highboy's Avatar
montana_highboy
Old wive's tale that just refuses to die, scenario... you park your truck outside overnight and the ambient temperature is below zero, the valves, ports, block, heads, etc. and air inside the engine are all at or below zero, you start the engine and it fires up and the first thing that happens as the gas ignites is 900 degree combustion temperatures hit the cold exhaust valves, do the valves warp? No, do people who live in cold country have to do valve jobs every year? No.
Old Dec 18, 2011 | 12:13 AM
SuperDuty93
Haha. U have no idea how fast this thing is. It hauls A**! Between the Holley Double Pumper and the hot cam, oh and the shift kit! it just takes off like a rocket. I luv it!
And when you say "uncap", what do you mean?
Old Dec 18, 2011 | 01:16 AM
bamaf150's Avatar
bamaf150
Not quite the same scenario as exhaust valves at operating temp when cold air rushes in as in no exhaust manifold. IDK if there is any truth to it or not but I dont think you have any worrys with open headers. Uncapped just means disconnected at the collectors.
Old Dec 18, 2011 | 01:27 AM
SuperDuty93
Ah. Mkay. What i think ill do just 2b on the safe side is do 2' of 3" and have is go into a 90 deg elbow. Not open but close enough
Old Dec 18, 2011 | 08:50 AM
fasthauler's Avatar
fasthauler
Definetly old wives tale. We use to run short stacks on dragsters all the time. By the time the air gets back to the valves it is superheated and is the same temp as the valves or close enough to not cause any problems. (just another opinion)
Old Dec 18, 2011 | 11:33 AM
73 fourxfour's Avatar
73 fourxfour
I use to uncap my mustang when I was younger. I loved the way it sounded when I first started it up but I grew tired of the loudness and reverb along with the loss of torque. If you want loud and are concerned about the valve issue why not just remove the mufflers from the system. It will still be quite loud, but behind you, won't loose as much torque, and being that we're in California, more likely "Ponch" won't pull you over.
Old Dec 18, 2011 | 01:26 PM
montana_highboy
Agreed! WWII aircraft piston engines ran with 10" short pipes with air temperatures at altitude of -20 degrees or lower and never had trouble with warped valves.
JakeTheSnake
Jul 22, 2006 12:34 AM
buttnuttn8
Exhaust Systems
Mar 30, 2006 07:14 AM
1969FordF250
Aug 29, 2004 12:56 PM
foofoo
Exhaust Systems
May 11, 2004 05:43 AM
Timothy509
13
Mar 20, 2004 02:41 PM
