open headers on diesel
Old May 2, 2004 | 08:40 PM
foofoo's Avatar
foofoo
Talking open headers on diesel
i have a 1992 f-350 and i was wondering if running open headers will make the truck loud?
Old May 2, 2004 | 09:28 PM
ford5.8's Avatar
ford5.8
Yes it will be very loud..
Old May 2, 2004 | 11:05 PM
RawPower's Avatar
RawPower
By open headers, do you mean getting rid of all exhaust components except for the deaders?
If so:
UH. LOUD LOUD. Turbo does help cancel out a good bit of the sound waves, but not enough. Not only that, youd dry up every rubber O-ring, seal, grommet, etc. inside your engine bay, and more under the cab. Your engine bay temperature would increase, and probably conaminate your air supply while at idle, and youd loose horsepower (every 5 degrees equals 1 hp). It would probably make it into the cab as well, so you might want to drive with a gas mask (might get pulled over, some old lady might think your a terrorist or something). When you turn off your truck, the cold air on the headers and exhaust valves inside your block will cause the hot metal to crack and will be ruined. In short, DONT DO IT!!!
Old May 3, 2004 | 10:29 PM
wildjon300ci's Avatar
wildjon300ci
He has a 1992....there is no turbo on that truck...Food for thought
Yes, it WILL be loud. Try it for a day and see how bad your head hurts.
Old May 3, 2004 | 10:48 PM
foofoo's Avatar
foofoo
loud but illegal????
Old May 6, 2004 | 08:24 AM
nogo73's Avatar
nogo73
I ran with no muffler on mine I got hassled by the local cops. it was really loud if I was pulling a load. yes it is illegal in most areas check with local law enforcement. I running headers with flowmasters on 3" exhaust not bad for the power. o yeah I had to down grade I crack my7.3 and bought a 6.9 still got the power though.
Old May 6, 2004 | 06:24 PM
foofoo's Avatar
foofoo
also i wanted to know if you can put open headers on a mack big rig
Old May 6, 2004 | 08:16 PM
ford5.8's Avatar
ford5.8
Why would you want to do such a thing??? You can stright pipe the mack but I dont see why you would want a open manafold..I dont think they make headers for big rigs..
Old May 6, 2004 | 08:48 PM
95 F150's Avatar
95 F150
foofoo are you sure you're not full of poopoo
Old May 6, 2004 | 09:08 PM
foofoo's Avatar
foofoo
Yeah I guess so because I didn't take a **** yet
i don't have a mack truck but wanted to know if it was possible because one of my friends was talking about making his rig louder and since i was on this thread i thought about asking it.I really want to know if open headers on my 350 is illegal and if it will harm the truck.Is there any documents on the web about emmision laws in the state of texas that anybody knows about?
Old May 7, 2004 | 05:59 AM
nogo73's Avatar
nogo73
screw headers when you can have lots of boost. if the 7.3 and 6.9 had lower compression the a huge turbo would be a total standard a cross the board. diesels need air and lots of it. if you want to have a loud truck buy a chevy its cheap to replace burnt valves in the 350 then it is in a ford diesel to get a long block from ford or international will run you $6000. I can rebuild a 350 for under a grand.
the only reason I went with headers is I was curious if they would give me more power than a turbo but If I could do it all over again I would buy the banks sidewinder and intercool it.turn up the pump crank the boost and watch out I'd probably be on my 3rd motor too or 4th.
Old May 10, 2004 | 12:20 AM
faroffthetrack's Avatar
faroffthetrack
Get some stacks
Old May 10, 2004 | 05:21 AM
nogo73's Avatar
nogo73
If I had stacks they would probably busted off by now my cab sits about 6'7"(I'd have two nice 6" stacks comming a a foot over the cab) I can barely put it in the garage. I love to do it though that way you don't have to clean soot off the truck or trailer if you put them high enough. straight cut ones will put soot all over the surroundings after they get water in them.
Old May 10, 2004 | 09:34 AM
jaydez's Avatar
jaydez
any time you have no exhaust its loud. my brother has a 91 talon Tsi, AWD trurbo that the exhaust fell off of at the downpipe so it dumpped out after the turbo. he was making 4 lbs of boost at idle. and the thing was LOUD and that was only a little 2.0L 4cyl.
Old May 11, 2004 | 05:43 AM
AYoungblood's Avatar
AYoungblood
hahah!!!
Im sure it will be illegal unless you live in the middle of no where.
Just run headers with a stright pipe or headers with a nice muffler.
jack orchard
May 7, 2020 10:16 AM
BOB FERGUSON
15
Jul 21, 2014 08:23 AM
fastblast12
Feb 25, 2008 07:15 AM
idgit0488
Exhaust Systems
Jul 6, 2006 02:54 PM
Hamstersbane
Jul 5, 1999 10:23 PM
