Frame Swap
Old Dec 17, 2011 | 04:34 PM
Redneck1465's Avatar
Redneck1465
Frame Swap
I have an 85 F150 truck that I want to swap to 4x4 and I have a cummins that will be going into the truck. I have a donor F250 truck with all the suspension and the 4x4 but obviously the F250 is TTB and I have been told that with that and the leaf springs its obviously not a bolt in swap you need to fab a little. I came across a 2003 frame from an F350 4x4 that is the same extended cab 8ft bed for pretty cheap. Has anyone ever swapped our bodies onto these frames before when they are restoring trucks? And if so how did it go? Just an idea not set in stone. Thanks guys.
Old Dec 17, 2011 | 04:39 PM
dohc_chump's Avatar
dohc_chump
This space for rent...
Why not swap the F150 body onto your F250 chassis? Am I missing something?
Old Dec 17, 2011 | 04:42 PM
Redneck1465
F150 is extended cab 8ft bed. F250 is regular cab 8ft bed they are not the same length therefore not going to work. Also cab is shot on the F250 way beyond repair even if I wanted a single cab (which I don't).
Old Dec 17, 2011 | 05:03 PM
dohc_chump's Avatar
dohc_chump
Ah, I see. Sounds like it's time to bust out the old tape measure and start measuring both frames.
Old Dec 17, 2011 | 05:21 PM
Redneck1465
I would but the problem is the frame is about 1.5 hrs away and I dont want to drive there just to measure and find out its wrong. I was just hoping maybe someone else had done this swap already. THanks for the info
Old Dec 17, 2011 | 05:29 PM
dohc_chump's Avatar
dohc_chump
Ok, frames a ways away, but you got to have a used car lot in town with one in inventory? I doubt you'll find someone who's done this swap when there are still tons of the 80-96/97sd trucks hanging around for cheap. So in your case you'll probably have to either measure for yourself or find someone willing to measure their truck for you.
Old Dec 17, 2011 | 06:33 PM
fellro86's Avatar
fellro86
That's about the only way you will figure it out, as you are doing something that generally isn't really considered due to so many things different. I doubt anything will be a straight swap, it likely will require a large amount of fabrication.
Old Dec 17, 2011 | 07:27 PM
Redneck1465
Yeah thats what I was thinking. Thats why it was just an idea. I would prefer to find a F350 frame from 80-97 it would make it so much easier to do.
Old Dec 17, 2011 | 09:15 PM
Franklin2's Avatar
Franklin2
The front of the f150 frame is way different than the f250. So putting the f250 stuff under the f150 frame would be a total fab job the whole way.
Old Dec 18, 2011 | 01:57 AM
Redneck1465
Yeah I know thats why I am not putting the TTB on the F150.
70 Maverick
Mar 10, 2009 11:28 AM
sedly
18
Feb 22, 2008 11:10 PM
65mustang
Nov 11, 2004 01:07 AM
WOLVERINE1
Paint & Bodywork
Jul 10, 2004 08:52 PM
capt
Jan 15, 2004 08:47 PM
