Swap
Old Jan 15, 2004 | 01:19 PM
capt's Avatar
capt
Swap
Can you swap a 76 f-250 cab and bed on to a 79 f-250 frame? Also, can you do the same with the leaf springs too?
Old Jan 15, 2004 | 01:50 PM
TremecGT's Avatar
TremecGT
In a word, yes. But you will need to make sure that the wheel bases are correct. Assuming they are both shortcab long bed 2wds it should be a fairly simple swap. As for the springs, my guess is that they would work also.
Old Jan 15, 2004 | 02:04 PM
capt's Avatar
capt
So if they are both regular cab, long bed, and 4x4. Then they should be able to swap between the too.
Also thanks for the reply.
Old Jan 15, 2004 | 03:27 PM
Nathan's Avatar
Nathan
If the 76 is a 4x4, the back of the cab connects to the frame via brackets bolted to the outside of the frame. It can be modified to work, though.
Nathan
Old Jan 15, 2004 | 08:47 PM
bpete's Avatar
bpete
I swapped a 73 F-250 4x2 cab onto a 79 F-150 4x4 no problems except for the wiring -- so I changed cab wiring also. I think there are 2 different width springs on rear 3in. & 2.25in. but lenghts are the same. they may also differ in # of springs in leaf pack. Front springs I belive are the same width but different in # of springs in leaf pack.
jimlj
Sep 26, 2012 06:59 PM
DShuler
15
Feb 26, 2008 10:20 PM
ejolliffe
15
May 18, 2007 02:30 PM
63SW250
Dec 10, 2004 06:39 PM
