problem installing warn hubs
Old Dec 17, 2011 | 04:25 PM
rojami's Avatar
rojami
i installed a set of warn premium hubs the drivers side went in fine but the passanger side i cant slide it in far enough to get the lock ring secured took my tape and there is a 3/16 difference i am thinking it might be the wonderful rotor hub i got at advanced auto anyone else have this problem i would appreciate any responce before i take the rotor off and hurl it through the front window at advanced
Old Dec 17, 2011 | 04:35 PM
bashby's Avatar
bashby
If you are talking about the small snap ring that goes on the axle (about 1" diamater), try sliding the axle out by prying at the u joint. It should move in and out with little force.
Old Dec 17, 2011 | 04:44 PM
rojami's Avatar
rojami
no its the bigger retaining spring that fits in the groove onthe inside of the hub i can get the snap ring in ok it seems like the groove needs to move toward the outside about 1/8 to maybe 3/16
Old Dec 17, 2011 | 05:32 PM
bashby's Avatar
bashby
I'd try that hub on the other side and the other hub on that side.
Old Dec 17, 2011 | 06:27 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
it's one or the other.which is the correct statement?
wheel bearings both look ok?
Old Dec 17, 2011 | 06:38 PM
rojami's Avatar
rojami
miss typed i cant get the unit slid in far enough to get the lock ring to fit in the groove
Old Dec 17, 2011 | 06:40 PM
rojami's Avatar
rojami
wheel bearings are 5 months old changed both when i installed new rotor seems like the goose neck doesnt comeout far enough i will take mesurements tomorrow and see if it isnt a bad cast in the rotor it was made in china
Jakesford
Sep 1, 2017 02:28 PM
54Hydro
15
Jan 5, 2014 12:06 AM
Boss08v10
Jan 31, 2012 11:21 PM
hpcbmw
Apr 25, 2011 09:22 PM
1bgredtk
Jul 4, 2004 04:17 PM
