2001 Explorer CD Disk Error Message
Old Apr 16, 2003 | 10:26 AM
abpinkney's Avatar
abpinkney
Question 2001 Explorer CD Disk Error Message
I have a 2001 Ford Explorer. Some months ago, I was playing a cd that was burned by a friend. Ever since I have been unable to use my cd player. The radio works fine.
I can put a cd in, and it tries to start, but always displays a "disk error" message.
Please help. I am driving 1200 in 2 days and I NEED my music . I have been trying to find someone locally, but I think the problem is pretty simple. I don't want to pay hundreds of dollars if I don't have to.
Old Apr 16, 2003 | 02:04 PM
thelonerangerxlt's Avatar
thelonerangerxlt
I have no idea it this will work or not, but you might try removing the negative battery cable for a couple minutes. This will remove the memory from the Radio/CD.
Or if you can find the fuse for it, just remove and replace the fuse. That will do the same thing, and you might not have to reset the clock.
Old Apr 16, 2003 | 02:29 PM
abpinkney's Avatar
abpinkney
I just had the truck serviced for the trip and they did exactly that...Any other suggestions? This did not fix the problem
Old Apr 16, 2003 | 03:37 PM
The Titan's Avatar
The Titan
Could it be that a stick on lable come off of the cd. In my 2003 owners manual Ford recomends against using labels on home burned CDs
Old Apr 16, 2003 | 07:40 PM
PrPlayboy's Avatar
PrPlayboy
if it had a home label the cd may have been too thick and caused damage to the cd pick up laser. Try using a CD cleaner. Some cleaners even have small brushes on them. I have also heard of poorly burned Cd's making cd players run very hot and cause damage to internal components.
Old Apr 17, 2003 | 06:35 PM
hockeytodd's Avatar
hockeytodd
Lightbulb 2001 Explorer CD Disk Error Message
I had a cd error, is it a 6 cd pack ? Is 1 cd stuck inside? I have a 2002 explorer. Somehow a cd came loose I had to put a piece of paper underneath the cd to eject it. It was a burned cd. Or do you use colored cd's some systems wont play them. I don't think these are the problems but I figure anything might help.
Good Luck
Hockeytodd
Old Apr 17, 2003 | 11:31 PM
abpinkney's Avatar
abpinkney
I bought a cd cleaner (with the little brush on it) and it allowed me to put it in, but it still won't play. I couldn't even get it to accept the cleaner.
Any other ideas?
By the way, it is a single cd.
Lloyd78
Feb 5, 2015 04:00 PM
BaitGuru
Sep 15, 2009 08:02 PM
bri687
Aug 20, 2007 12:28 AM
bbillman
Jun 6, 2007 07:02 PM
jlarem
Feb 9, 2002 07:19 AM
