fuel sender issue
Old Mar 27, 2011 | 02:51 PM
capitan72's Avatar
capitan72
fuel sender issue
Help me out with this one... My forward tank always shows empty on the gauge, my rear tank works fine. I pulled the tank, pulled the sender and plugged it in without the tank. It worked. So I figured it got stuck or something but just to make sure i checked continuity and resistance, they both seemed correct. Put it all back together (lined up the arrows)with fresh fuel and gauge shows empty again.
What am I missing?
1994 IDI 2WD supercab
Old Mar 27, 2011 | 03:57 PM
farmert's Avatar
farmert
I wouls saya a bad wire between the front tank, and the fuel selector valve. The back tank gauge works, so that tells me the wire is good from the selector to the dash. the FFS is located in the drivers side frame rail at the rear of the cab.
cchvacman
Aug 10, 2014 03:30 PM
Ninra
Oct 6, 2013 08:52 PM
lhutter1
Jan 15, 2013 06:06 PM
drumfield
Electrical Systems/Wiring
Aug 7, 2011 07:33 PM
scarl
Sep 7, 2003 08:55 PM
