engine question
Old Dec 17, 2011 | 12:56 PM
Jens's Avatar
Jens
engine question
Hello
is anybody here who knows 501 cid FE/FT engine?
Thanks
Jens
Old Dec 17, 2011 | 01:28 PM
69cj's Avatar
69cj
There is none stock. You would have to go stroker to get those cubes.
Old Dec 17, 2011 | 01:41 PM
Sleepy445FE's Avatar
Sleepy445FE
That cid is only attainable with an aftermarket 427 block and a 4.25" stroker crankshaft. It will be an FE not FT also.
Why are you interested? Is there something we can help you with?
Old Dec 17, 2011 | 04:18 PM
jowilker's Avatar
jowilker
Jens, Might you be referring to the reverse image 105 on the front of your FE engine?? It is most likely a 360, but could be a 390, if that is the case.
John
Old Dec 17, 2011 | 06:39 PM
Sleepy445FE
I bet that's it John!
That's probably what's got him confused. Jens, is there are mirror 105 cast into the drivers side front of your block just beneath the head?
Old Dec 18, 2011 | 11:10 AM
Jens's Avatar
Jens
Hello folks,
thank you very much for your replys.
The story behind this engine is that a user from our Lincoln Forum found that engine and brought in home. He does'nt that kind of engine, he only know the 385 family, the 460 cid which is installed into his Mark IV.
I told him that it must be an FE or FT engine (indicated by pics) but he means that the castnumber indicates it as 501 cid. I told him the there is no 501 in any Ford V8. Than he send me an pic from a label which shows and engine displacment of 391 EHD 4V.
Any Idea what "EHD" means?
Thanks
Jens
I unfortunetely can add pic here, no Idea why
Old Dec 18, 2011 | 11:32 AM
Rogue_Wulff's Avatar
Rogue_Wulff
391 would be an FT medium duty truck engine. Not much value to anyone that doesn't have a medium duty truck, aside from the block. They can be used to build an FE.
Old Dec 18, 2011 | 02:10 PM
Bear 45/70's Avatar
Bear 45/70
Actually Ford had some 500 CID engines in their bigger trucks some years ago. Look here;
401, 477, & 534 SD Engines - Ford Truck Enthusiasts Forums
Old Dec 18, 2011 | 02:49 PM
Jens's Avatar
Jens
Thanks for the link.
What i mean is that Ford never build gasoline engines with more as 462 cid for automobile use or am I wrong?
Jens
Old Dec 18, 2011 | 04:34 PM
Bear 45/70's Avatar
Bear 45/70
Jens
Nope, the 462 MEL engine was the biggest used in the Lincolns.
Falconman#3
Apr 24, 2019 12:52 PM
chukar
Jul 1, 2017 12:01 PM
Salty Dog
Feb 21, 2014 04:58 PM
jrmandryck
Jul 11, 2009 01:46 PM
Duke78
27
Nov 30, 2008 10:28 PM
