Jens, Might you be referring to the reverse image 105 on the front of your FE engine?? It is most likely a 360, but could be a 390, if that is the case.
thank you very much for your replys.
The story behind this engine is that a user from our Lincoln Forum found that engine and brought in home. He does'nt that kind of engine, he only know the 385 family, the 460 cid which is installed into his Mark IV.
I told him that it must be an FE or FT engine (indicated by pics) but he means that the castnumber indicates it as 501 cid. I told him the there is no 501 in any Ford V8. Than he send me an pic from a label which shows and engine displacment of 391 EHD 4V.
391 would be an FT medium duty truck engine. Not much value to anyone that doesn't have a medium duty truck, aside from the block. They can be used to build an FE.
