Engine back together VERY rough idle
Old Dec 15, 2011 | 04:44 PM
WillFargo's Avatar
WillFargo
Exclamation Engine back together VERY rough idle
Hey all.
Just got everything put back together after the rebuild. It runs great except for the idle. its bumpy and almost dies sometimes and is just really, really rough. once i start accelerating, it drives perfect though. Im on break between jobs right now so i dont have time to do any investigating until tonight, so i was hoping to get some ideas from ya'll.
So far here's my plan:
-Replace fuel filter
-clean Idle Air Control Valve(should i replace it?)
already cleaned the MAF, tried turning the idler screw up a bit. smoothed it out a little but obviously wasnt the culprit.
-I sprayed carb cleaner around at the vacuum lines, didnt find anything wrong there. only check engine code thats coming up is egr excessive. the car has always been throwing this light, i've never figured out why. all egr components had been replaced with no success at getting rid of the light.
So what does anyone think? any ideas would be great!
Thanks!
Old Dec 15, 2011 | 05:40 PM
WillFargo's Avatar
WillFargo
Well after a bit of research i have decided it may be the intake manifold gasket leaking. mainly because the symptoms seem to match, and there is a hissing noise.
If i spray some carb cleaner on it, the rpms should rise for a moment, correct?
Old Dec 15, 2011 | 09:04 PM
shorod's Avatar
shorod
Yep. Your symptoms are consistent with a vacuum leak. Before disassembling the intake you may want to fist make sure the intake air tubing between the MAF sensor and the throttle body is properly connected and not cracked.
-Rod
Old Dec 15, 2011 | 09:43 PM
WillFargo's Avatar
WillFargo
well shoot! i sprayed all along the vacuum lines, didnt notice any RPM changes anywhere
Old Dec 15, 2011 | 11:39 PM
WillFargo's Avatar
WillFargo
Update: Sprayed along all vacuum lines AGAIN, 2 times actually. sprayed all around intake (hissing noise was from intake), cleaned IAC(was humming as it had before when i had issues with it).
What on EARTH could be going wrong here? i'm at the point where i may just take it to the shop for diagnosis, but would hate to do so.
Old Dec 16, 2011 | 05:33 AM
SEAL1's Avatar
SEAL1
I had the same thing and sprayed carb cleaner everywhere with no RPM change. Finally replaced the intake gaskets and magically, no more problem. You can not think that carb cleaner will reveal all vacuum leaks. It doesn't.
Old Dec 16, 2011 | 01:50 PM
WillFargo's Avatar
WillFargo
intake gaskets are brand new. everything is brand new
Old Dec 16, 2011 | 07:46 PM
shorod's Avatar
shorod
Do you happen to have access to a scan tool with datastream mode so you can monitor various sensors and parameters to identify one or two that are not responding like they should? Maybe you have a lazy fuel injector, and out of range engine coolant temperature sensor, or some other sensor that is unplugged.
-Rod
Old Dec 16, 2011 | 10:58 PM
WillFargo's Avatar
WillFargo
Ya i have a craftsmen scan tool with live data. im thinking i may take the intake off and inspect it. i have an appointment at the auto shop on tuesday, but i would like to avoid the fees from that if i can identify the issue. the symptoms just sound so indicative of an intake manifold leak that i cant stop thinking that its the issue.
one thing im questioning is that the gasket i got for the lower intake looks like the one in this set:
Buy Felpro Intake Manifold Gasket Set MS 98005 T at Advance Auto Parts
but the one in this set:
Buy Felpro Intake Manifold Gasket Set MS 95739 at Advance Auto Parts
looks more like what my chilton manual showed. im thinking maybe the bead of RTV where it specified (Apply RTV silicone gasket material at the junction points of the heads and manifold.) may not have been enough.
Do you think this may be a cause of my issue?
evan_nugget
Mar 22, 2018 07:11 PM
betard_foosier
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 19, 2014 05:25 PM
guitarnik
Nov 30, 2008 01:40 PM
Dale McLenaghan
May 12, 2008 04:49 PM
uy7v
Mar 21, 2002 12:36 PM
