Sponsored by: Real Truck
2000 PSD ABS Light
Old Dec 14, 2011 | 08:34 PM
superstroker123's Avatar
superstroker123
2000 PSD ABS Light
So today when i was driving to work I came up on a stop light and did the normal hit the brakes to come to a stop and my truck acted fine as i took off of from the light my ABS light came on and has not gone off since i dont know where to start any help would be awesome
Thanks
Gibbie
Old Dec 14, 2011 | 09:40 PM
jmiley's Avatar
jmiley
Thanks
Gibbie
Mine has been on and off for the past 8 years, never worried much about it, the brakes still work fine.
Could be a wheel sensor.
Old Dec 14, 2011 | 09:44 PM
superstroker123
yeah thats what i have been reading that they have some issues but never stop working it seems to me that nothing has changed with it other then the light is on about 8 months ago i did wheel bearings so it shouldnt be on the front are there wheel sensors on the back
Old Dec 14, 2011 | 09:52 PM
jmiley's Avatar
jmiley
Yes there are wheel sensors on all 4 wheels, they all have to have sensors otherwise the antilock system wouldn't know if one wheel was locked up or not.
The antilock brakes on the 2012 is a lot better than the 2000, but it did cost twice as much, the2000 has good brakes but the 2012 has great brakes, the best I have ever had on a vehicle.
Just because you did wheel bearings doesn't mean you haven't lost a sensor, if you chipped one of the teeth off the hub that could cause you problems or a sensor may have went out.
I never worried about it onthe old truck.
Old Dec 14, 2011 | 10:01 PM
superstroker123
i also read that it could be a sensor on the rear end diff
Old Dec 14, 2011 | 10:14 PM
jmiley's Avatar
jmiley
could be, get a service manual and start checking it out or do an online search for how to troubleshoot the problem, don't just start replacing parts.
Old Dec 14, 2011 | 11:15 PM
AllaboutMPG's Avatar
AllaboutMPG
Check your brake lights and cruise as well. If either are not working it could be your brake light switch at the brake pedal. I was having trouble with mine. Pulled the switch out and took it apart, cleaned the contacts and now all is well.
Old Dec 18, 2011 | 08:52 PM
iknfixit's Avatar
iknfixit
Father in law has a 2000 ranger and just took it a couple days ago since ABS lite came on. They only replaced a sensor...don't know which one.
I have a 2007 250....my ABS lite comes on during a full right turn of wheel or when the pump seems to have pressure on it. just tightend a leaking high pressure pump to hydroboost last week.. Wonder if there is a setting to re-center or something
99ExpyProblems
Sep 10, 2013 09:09 AM
Nick 99
Sep 22, 2011 01:14 PM
dao57
1997 - 2003 F150
May 11, 2005 12:37 AM
fordnut74
Sep 22, 2004 07:18 PM
bigoq45
Electrical Systems/Wiring
Aug 30, 2003 11:18 PM
