"abs" light will not reset on 2000 Exp
Old Aug 29, 2003 | 08:40 PM
bigoq45's Avatar
bigoq45
I replaced the disc brakes(4) the abs light was on prior to changing pads. NEEDS HELP PLEASE
Old Aug 30, 2003 | 11:18 PM
Franklin2's Avatar
Franklin2
Some guys on here where saying if you first start the truck up and just sit in the driveway, and the light is not on, but does come on when you start moving, there is a problem with one of your wheel sensors, or the tooth ring at the wheel where the sensor reads.
