Sponsored by: Real Truck
Kick Panel help
Old Dec 14, 2011 | 07:33 PM
Vermont Original's Avatar
Vermont Original
Question Kick Panel help
Is there any trick to getting the pass. kick panel off? Im putting cab lights on and I need to get in there. Anyone know the easiest way to get it off?
Thanks guys
Old Dec 14, 2011 | 10:00 PM
jetact's Avatar
jetact
Thanks guys
What year is your truck. Always put that in posts until you can make a signature.
Old Dec 14, 2011 | 10:06 PM
Ford SD's Avatar
Ford SD
I'm new as well and just ordered JC Whitney's Pacer Performance cab lights (OEM style). However mine do not come with a harness. I imagine you purchased the actual lights and harness from Ford. How much did the parts set you back?? I think mine came to about $54 with free shipping. If I don't have a harness should I run it through a switch or just run it off the parking light wire?? If I do it to the parking light wire is that too much of a draw?
Old Dec 15, 2011 | 12:36 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
The panel should just pull off.
Old Dec 15, 2011 | 06:48 AM
Vermont Original
Sorry guys, My truck is a F250 1999 V10 crew cab.
Old Dec 15, 2011 | 06:50 AM
Vermont Original
The package I got came with the lights and harness and it was about 90 bucks for everything. Then I got silicone II to seal the lights better, which was about 6 bucks.
Old Dec 15, 2011 | 08:10 AM
1975StroppeBaja's Avatar
1975StroppeBaja
You have to remove a push-in clip that's near the floor behind the parking brake pedal.
You can see the round post for the clip in the middle of the pic below. And you can see the clip beside my meter in the second pic below.
Once you pull that clip out, you just pull the kick panel straight back toward the rear of the truck. Not inward toward the transmission tunnel, straight back.
Island'r
Feb 5, 2013 09:05 PM
erniek70
Oct 28, 2010 10:52 AM
X36
Jun 9, 2008 07:24 PM
mike_23us
Electrical Systems/Wiring
Feb 18, 2004 01:01 PM
