FICM voltage fluctuating
Old Dec 14, 2011 | 09:22 AM
LSAtexan4x4's Avatar
LSAtexan4x4
I just installed a known good FICM and the voltage is all over the place between 22.5 and 48. Good batteries. It is an 03 model and mine is an 05 model.
Thanks
Old Dec 14, 2011 | 10:24 AM
cartmanea's Avatar
cartmanea
Sounds like it's not a good FICM. How are you guaranteeing it's known to be good?
Old Dec 14, 2011 | 11:11 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
It MAY have to be programmed to your system.
Old Dec 14, 2011 | 11:13 AM
cartmanea's Avatar
cartmanea
Programming won't affect the voltage output.
Old Dec 14, 2011 | 11:33 AM
69cj's Avatar
69cj
Make sure the harnesses are snapped in tight.
Old Dec 14, 2011 | 01:00 PM
LSAtexan4x4
I'm borrowing the unit and it was reworked. I'm not guaranteeing it but I just assumed. I'll recheck connections tonight
Old Dec 14, 2011 | 03:12 PM
dchamberlain's Avatar
dchamberlain
I seem to recall reading here about some people having problems with the grounds. Attaching a separate ground from the FICM to a good block ground solved the problem. Maybe you've got something like that going on.
dreamofford
May 30, 2017 01:59 PM
fifty-two_f1
13
Aug 20, 2014 11:14 AM
Wicked Mainah
Sep 2, 2013 06:42 PM
felton
Jan 23, 2013 10:49 AM
adbecker
Oct 11, 2000 12:20 PM
