My question for the month...
Old Dec 13, 2011 | 08:57 PM
cwindsor's Avatar
cwindsor
Okay okay I will have plenty more I'm sure...
I have a 61 uni with a 286 on a c4 tranny.... The problem I have is It will switch between first and second smooth as butter. But wont go into thrid...
I have replaced the modulator and check for Vac on it.
I have the Vac coming from a 4 barrel holley. Someone told me to move the Vac line to come off the intake manifold for better Vac...
What do you think?
Old Dec 14, 2011 | 02:05 AM
37 Ford guy's Avatar
37 Ford guy
hmmmm....maybe there's something wrong in the valve body that won't let it shift to 3rd. It obviously has enough vacuum to shift from 1st to 2nd.
Just a thought....
Old Dec 14, 2011 | 05:25 AM
jowilker's Avatar
jowilker
Vac. on the intake is proper placement for the line to the tranny. I have a stalk that runs the brake booster & tranny on mine.
Since you have a swap in, you might have shift alignment issues. Get the truck stabilized, wheels chocked, go under and check the clicks on the the tranny itself against the column position. You have to have it right on the tranny end even if you miss at the column. Remove the nut at the shift arm/shift linkage and calibrate it.
The alignment could be off and the tranny not actually be in drive. Been there done that.
John
trumsey07
Nov 5, 2013 04:31 PM
josher66666
Jan 28, 2009 12:18 AM
Syntheglass
Aug 11, 2004 08:22 PM
quads
Nov 10, 2000 03:23 PM
rodney
Jan 7, 2000 08:28 PM
