tranny not shifting properly
Old Jan 27, 2009 | 05:36 PM
josher66666's Avatar
josher66666
I just finished putting my engine back together after putting a new intake carb and timing set on. This was the first time i have ever done that stuff before and it seemed to go pretty smooth. The problem came when I got out on the road and took off for the first time. The shifting is all wrong. Inever messed with the tranny so I am clueless. Any help would be great. Thanks alot guys.
Old Jan 27, 2009 | 05:58 PM
timothy47129's Avatar
timothy47129
You need to be a bit more specific.like it feels like its slipping,its shifting too late,its shifting too early,its not kicking down for passing, That kind of thing.
Tim
Old Jan 27, 2009 | 06:01 PM
fromm's Avatar
fromm
You might check and see if the vacuum line is hooked up to your transmission from your intake manifold. The tranny should have a vacuum modulator, that helps your tranny shift smoothly. You might also check and make sure the kick down cable is hooked up.
Old Jan 27, 2009 | 06:03 PM
unrulee's Avatar
unrulee
Yep, check the vacuum line first. Easy fix. I've had mine come off and it's not a pleasant expirience. The truck won't shift to the next gear till something like 3500-4000 rpm!
Old Jan 27, 2009 | 06:08 PM
murph77's Avatar
murph77
I vote vacuum line also. My only experience with this issue was with a '75 chevy, but I do remember that I could still get it to shift using the gear selector (1, 2, 3) in the mean time. I did a rebuild and misplaced that line. Didn't realize it was missing until I drove to the exhaust shop. Oops.
Old Jan 28, 2009 | 12:18 AM
bmuhlbach's Avatar
bmuhlbach
kick down for passing gear?
