New Carb
Old Dec 15, 2011 | 10:15 PM
  #46
Gary Lewis's Avatar
Gary Lewis
Yep. Find what works for you and the specifics of your engine. it won't cost a penny and you will learn a lot. Sounds like a pretty good return on your investment.
Old Dec 16, 2011 | 06:29 AM
  #47
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
One of the issues I used to see was some engines liked full vacuum on the advance at idle, others didn't. Chevrolet engines would backfire under sudden throttle opening with ported advance, they always used direct vacuum until 1968. Chrysler engines would misfire horribly with direct vacuum at idle, most of them ran 12.5 degrees static timing. Ford used ported spark for years.
One item will be how much manifold vacuum your cam will give you at idle, if it isn't enough to fully advance the vacuum advance them the idle will be unstable. At least with a manual trans it isn't as big a problem as with an automatic.
Old Dec 16, 2011 | 07:49 AM
  #48
lavatan's Avatar
lavatan
I'll get the new carb on the 21st. 5 days seems like a lifetime now...
Old Dec 16, 2011 | 08:53 AM
  #49
Gary Lewis's Avatar
Gary Lewis
Therein lies the problem. If the cam is very mild, you have a manual trans, and you don't have A/C then almost any engine can be made to run properly at idle with manifold vacuum to the advance. Or, to put it another way, if your engine idles with very strong vacuum (mild cam) and you don't have things that tend to change the load on it (auto and A/C), then manifold vacuum works fine.
But, where I've had problems are when the vacuum at idle isn't sufficiently strong to fully advance the timing regardless of what else happens. In those cases I get an unstable idle. For instance, I've had engines set so they idle properly in gear with an auto, but take them out of gear and they run too fast. Or, the A/C compressor comes on and the R's drop which causes the vacuum to drop which causes the R's to drop....... and the thing falls on its face.
So, to say that all street engines should run manifold vacuum to the advance tells me the author of those words doesn't live in the real world - or at least the world in which I live. There are just waaaaay too many variables to make such a statement.
Old Dec 16, 2011 | 11:07 AM
  #50
85lebaront2
Gary, you hit the nail on the head, I wish I had a nickel for every kid with a 283 or 327 he put a hot cam in, curve kit in the distributor and couldn't figure out why his car ran at 1500 rpm in neutral, and would stall when he put the Powerglide in gear.
I used to keep a set of real heavy advance springs in my toolbox so I could essentially lock the advance and set a static timing, tweak the idle mixture and speed with no vacuum to get a baseline idle. Then I could go to my distributor machine and set initial centrifugal advance a little above that. If I had enough vacuum at idle in gear to work the advance I would hook it direct, if not I would use a ported vacuum source.
dirtfrmr57
15
Sep 26, 2018 03:16 PM
MadFrank81
Apr 26, 2010 05:49 PM
cbfomoco
17
Aug 30, 2007 12:15 PM
hunter1897
15
May 10, 2006 05:16 PM
stinkfist
Feb 22, 2005 03:02 PM
