1978 - 1996 Big Bronco
Passenger Window
Old Dec 8, 2004 | 02:19 PM
jrich14's Avatar
jrich14
Passenger Window
The window switch on the passenger side does not seem to work the window. The drivers switch for the passenger window works sometimes. I have noticed that if I am opperating the passenger window from the drivers side - and someone touches the switch on the passenger side- the window will stop. That shows me that the passenger side switch is still connected somehow. I obviosly have a switch problem but I dont know if it might be the drivers side switch or the passenger side switch.
Old Dec 8, 2004 | 04:34 PM
greystreak92's Avatar
greystreak92
The wiring for the switches passes through the passenger side first then runs across to the driver's side. Check the passenger side switch for proper operation first.
