tranny swap
Old Dec 13, 2011 | 09:08 AM
zakk's Avatar
zakk
tranny swap
K guys so I bought an 86 for $600 bucks because it has a pretty new motor compared to my low compression junk pile 87 and the 86 is also has the better lookin front grill and its extended cab. So the 86 has a bad c6 that's why it was only $600 bucks but my 87 has a good c6 so I have pulled both trannys out already. Is there anything I should know before I put the 87 tranny in the 86?
Old Dec 13, 2011 | 09:43 AM
snaponprofile's Avatar
snaponprofile
pictures,....
Old Dec 13, 2011 | 10:18 AM
Lazy K's Avatar
Lazy K
If not already done might drain the `87 converter, pull and clean the pan, check intermediate band adjustment. Fill the `87 torque and trans with fresh fluid (around 13qts) when installed.
Make sure that you flush the `86 cooler and lines well before connecting up.
Old Dec 13, 2011 | 10:54 AM
IDIDieselJohn's Avatar
IDIDieselJohn
^^^^ X2 on the above!
Old Dec 13, 2011 | 12:19 PM
starmilt's Avatar
starmilt
I have always installed a new front pump seal while I had one out.
Old Dec 13, 2011 | 12:22 PM
IDIDieselJohn
Good idea!
Old Dec 13, 2011 | 12:24 PM
zakk's Avatar
zakk
I havnt really looked at the converter is there a place I can drain it from with out removing it from the tranny I heard you need to keep it attached or its hard to get it put it back on correctly
Old Dec 13, 2011 | 12:26 PM
zakk's Avatar
zakk
How much is the seal and where is it I don't know to much about trannys
Old Dec 13, 2011 | 12:35 PM
Lazy K's Avatar
Lazy K
There is a drain bung on the converter, look around the outside edge that is facing you for it.
The seal is about $2.00 but you would have to pull the converter to see it at the front of the trans. If you pull the converter before you drain it, fluid will pour out.
If you do pull the converter (just sldes off) you have to be sure that it is fully seated back in the trans before you install the trans.
Old Dec 13, 2011 | 12:45 PM
zakk's Avatar
zakk
So its not really a huge deal to take the converter off I just have to get it to seat correctly? How will I know if its seated or not
Old Dec 13, 2011 | 12:56 PM
Lazy K's Avatar
Lazy K
First push it fully back towards the trans and measure how far it is in from the bellhousing bolt flange at the minuite. When you reseat it rotate it as you feed it in until you feel it click into place, then measure again and make sure it is as far in as now.
If you do slide it off check the "nose" of the converter well for any signs of wear/grooves.
Old Dec 18, 2011 | 06:11 PM
zakk's Avatar
zakk
What is the electrical plug that's attached to the shift linkage on the tranny
Old Dec 18, 2011 | 07:58 PM
starmilt's Avatar
starmilt
I am not an auto guy at all, but I'm pretty sure it is your nuetral safety and reverse light.
Old Dec 18, 2011 | 08:29 PM
zakk's Avatar
zakk
I was thinkin that's what it is thank ya
Old Dec 18, 2011 | 10:18 PM
fellro86's Avatar
fellro86
That would be correct. I also highly recommend doing the pump seal, as it has a high probability of leaking after being disturbed. Better to do it now rather than have to do it over again after having just done it. BTDT.
1960 f100 4x4
Feb 18, 2012 10:23 AM
zakk
Nov 7, 2011 04:09 PM
Neds86
Aug 14, 2003 12:50 AM
