Fuel Filter empty
Old Dec 18, 2011 | 03:36 PM
'87F-2504X4's Avatar
'87F-2504X4
Fuel Filter empty
My truck had been sitting about a week and I started it to carry some trash out to the dumpster. It cranked fine and drove about 100 yards then the engine revved a bit then died. It acted like it ran out of fuel. Both tanks are full but I switched tanks and tried to restart. Nothing. Pulled the fuel filter and it was about half full. I refilled it and the truck fired and ran about 20 seconds before dying again.
I am thinking that the mechanical pump could have failed. Is this a good place to start?
When cranking over I do not get any fuel out of the schrader valve on the filter head.
Old Dec 18, 2011 | 04:47 PM
starmilt's Avatar
starmilt
Make sure you have fuel to the mechanical pump, if the fuel line is not restricted, or a major air leak, then it is your mechanical pump.
Old Dec 18, 2011 | 06:05 PM
bashby's Avatar
bashby
Yep. sounds like the lift pump or it's suckiing air between the pump and the tanks.
Old Dec 18, 2011 | 08:33 PM
'87F-2504X4
I checked the lines from the tank past teh selector valve and did not see any evidence of a fuel leak. I know that it can leak air but not diesel. When I get a chance I will crawl under it and pull the lines from the pump and check it. Probable won't be until Friday since I don't get home from work until well after dark and the truck is in the parking lot of the apartment with no outside lighting.
Old Dec 18, 2011 | 09:10 PM
starmilt's Avatar
starmilt
An air leak on that side of the pump, unless it is real bad usually doesn't have a wet spot, I have had to pressurize lines more than once to ever get fuel to leak, to find it.
If you happen to be able to get a piece of host to hook to the steel line on the frame by the pump, and siphon it you can usually rule out an air leak. You may have to spit out some diesel though and it tastes terrible. lol
Old Dec 19, 2011 | 01:57 AM
joshofalltrades's Avatar
joshofalltrades
now starmilt, don't make the rookie mistake of starting a siphon with your mouth. find a cheap hand pump. fuel in the mouth can make you a sick man. even fuel on the skin for enough time will.
znproperties
13
Apr 20, 2018 07:25 AM
Cjpower9185
Dec 22, 2015 10:47 PM
CarolinaRanger
Feb 12, 2015 03:15 AM
Ramonmonlea
Jan 2, 2014 03:55 AM
74hiboy
16
Jul 7, 2007 05:18 PM
