Post Foil delete
Old Dec 12, 2011 | 05:23 PM
omanalansan's Avatar
omanalansan
Post Foil delete
So i finally got to delete the foil, i love the sound but now i get a annoying hissing sound on the highway. Is this normal?
Help i'm about to take a 3 hour trip!! ha
Old Dec 12, 2011 | 06:03 PM
rbsample's Avatar
rbsample
The only hissing you should hear is the turbo "whistle" and for me anyway that noise is far from annoying.
Are you certain all of the pipes and clamps are tight?
Old Dec 12, 2011 | 06:20 PM
timmyboy76's Avatar
timmyboy76
hissing or wind thru a pipe, sound?
Old Dec 12, 2011 | 07:18 PM
omanalansan
How does a wind through a pipe sound like? I believe it's a hissing sound
Old Dec 12, 2011 | 07:27 PM
timmyboy76's Avatar
timmyboy76
hollow, howling sound, like making the noise when you blow air over an empty glass bottle...
Old Dec 12, 2011 | 07:32 PM
omanalansan
nope its definetly a hissing sound. I guess its suppose to sound like that after the foil mod?
I'll recheck to make sure all my clamps are properly tightened.
many thanks
Old Dec 12, 2011 | 08:57 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
What boost numbers you running,65-half throttle? Ebpv valve coming open?
Old Dec 12, 2011 | 09:46 PM
omanalansan
Umm I'm going to sound stupid but how do i check my boost numbers? and what is ebpv? oh o time to read more.
Old Dec 12, 2011 | 10:10 PM
rbsample's Avatar
rbsample
After you do the foil delete you will hear the whistle of the turbo much clearer. My guess would be if you just started to hear this new sound after you did the foil delete it may be air being sucked it through the boots or clamps. If this is in fact the case you don't want to suck in unfiltered air through the turbo. Be completely sure that pipe is tight when you reinstalled it. Unfiltered air into the turbo will damage it as well as the engine...quick!
Old Dec 12, 2011 | 10:40 PM
diesel-fitter-bum01
Do you have any gauges?
Old Dec 13, 2011 | 07:42 AM
omanalansan
no gauges but i do have the AE scanner, Can i drive around witht he laptop on and see the boost reading?
Old Dec 13, 2011 | 04:06 PM
diesel-fitter-bum01
On the base of the turbo pedestal there is a plug in/wire harness. Unplug it and see if it continues to do it. It will throw a code.
Old Dec 13, 2011 | 04:16 PM
Crewcab Turbo's Avatar
Crewcab Turbo
After doing my foil delete and 6637 I have had a few passengers ask if there leg was going to be sucked in by the turbo if they got too close to the dash! LOL It sounds cool to me. What you hear just may be normal.
stroke-of-luck00
Mar 1, 2009 09:11 PM
flajoker
Jul 7, 2006 11:35 PM
opnekryan
15
Dec 4, 2005 04:55 PM
turdbird
Jul 26, 2005 11:35 AM
Southernguy101
Exhaust Systems
Apr 7, 2005 11:09 AM
