Return Lines
Old Dec 12, 2011 | 04:58 PM
Crazy2's Avatar
Crazy2
Return Lines
Hi and am new here and also kinda new to IDI been long time scene i how own one ok what need to know what size are the o-rings for the return line caps and the return line hoses. just got this truck got drive it 500 miles to get home and have one cap leaking not sure if it the O-Ring or hose. last owner has replace the driver side and never did the other side. So just want for the time get the one cap from leaking intill get home to other kit for it
thanks for help ahead time
Bruce
Oh truck is a 1994 F350 crew cab DRW Turbo ,Auto Trans with 173,000 miles on it
Old Dec 12, 2011 | 05:17 PM
greywynd's Avatar
greywynd
The o-rings are #111's, get viton if you can. The hose however can be either 3/16" or 1/4", depending on which style of return line fittings you have. This just came up recently, but I can't recall which thread it was in.....I'm thinking your '94 should be 1/4", but not positive.
Old Dec 12, 2011 | 06:09 PM
starmilt's Avatar
starmilt
It is rare that you can do one cap and make it work. The problem is that these orings get heat hardened, but they generally hold until they are disturbed, there is no way to do a partial side without disturbing the others. I have heard of some getting lucky though.
Old Dec 12, 2011 | 07:12 PM
vfelix702's Avatar
vfelix702
lol i was not lucky..... i ended up breaking the brittle caps .... i used vition o-rings and the return line is 1/4in ended up having to run to the parts store and buying there kit...... for 80 as i needed my truck the next morning...
Old Dec 12, 2011 | 07:16 PM
Crazy2's Avatar
Crazy2
Maybe i,ll should just leave it alone right now in till get home with it just don't want problem going home i am pull 16,500 lb 5th wheel with it.
Scott in TX
13
Aug 3, 2018 10:23 AM
chillman88
Dec 6, 2016 08:29 PM
LSO1123
Sep 16, 2011 02:12 PM
mlouritt
Mar 1, 2011 05:47 PM
mechelement
31
May 4, 2010 03:48 AM
