New retrun line leaking on #1 injector
I installed new return lines a couple weeks ago on my '93 F250 N/A and it's developed a leak at the # 1 injector. It's not coming from under the cap like it would be if it were the O rings and I used new O rings and lubricated them good before I put the caps back on. It looks to be coming from where the two lines go on to the nipples of the #1 injector cap. Should I cut new sections of line and replace those two pieces or maybe try some different clamps that will hold tighter?
on
you got your kit from pensacola diesel.i recognize that leaky fuel line anywhere lol been there done that.
https://www.ford-trucks.com/forums/1...l#post10803260
you can hit up Russ too.i think he sells the Diapco kits,and i know he has the vitons as well.
the kit i got from my local parts store worked great, IIRC made by standard ( i could be wrong, its been a couple months and a few whiskeys), but hose clamps were green and it worked great. store currently bears the name "auto value" and has previously had the carquest and parts-plus names.
Wreckers.towing
05-23-2015 11:25 PM
deaninkc
35
10-26-2013 03:48 PM
mechelement
31
05-04-2010 03:48 AM
