Multiple questions/problems. Need help
Old Dec 11, 2011 | 04:47 PM
1949 F6's Avatar
1949 F6
I recently bought a 1989 F350 Diesel with an E40D. The tach doesnt work so I began to look into the fuses and other electronic junk around the e-brake. There is a 3 port round female connector that comes into the cab just right near the hood release cable. Any ideas on what this goes to? Does it have anything to do with the tach? It seems like the tach is dead most of the time but will jump up for a moment on occasion. I have read about PCMs and TECAs and axle sensors and what not but I dont know where to start. There are a few fuses missing out of my block, anyone have a diagram of that? These are the reasons I like sticking to old outdated technology (see username). A FTEr told me about the sensor on the engine and I will change that tomorrow. Thanks for the help!
Old Dec 11, 2011 | 05:47 PM
starmilt's Avatar
starmilt
I don't know how to test a tach sensor, but every bad one I have seen had the insulation on the wires seperating away from the sensor. Even some good ones have the seperation issue, though I suspect they are living on borrowed time.
Old Dec 11, 2011 | 08:03 PM
swimnshoot's Avatar
swimnshoot
The insulation on the wires coming out of my IP were bare so I put some liquid electrical tape on them and that cured my erratic tach.
Old Dec 12, 2011 | 06:18 PM
1949 F6's Avatar
1949 F6
I am going to check if NAPA has the tach sensor, Advaced Autoparts didnt. I put in 2 new batteries, new terminal clamps, and new alternator but my voltage gauge still shows low and my battery light is on. The harness that plugs into the alternator doesnt look so good, could that be the problem? Voltage regulator maybe? Any other ideas?
Old Dec 13, 2011 | 06:39 PM
1949 F6's Avatar
1949 F6
Charging issue solved. It turned out to be the voltage regulator however I changed out the alternator pigtail as well. NAPA doesnt show the sensor on the engine in stock, and none of the autoparts guys at various store seem to know what I'm talking about. Any ideas on where to get one?
Old Dec 13, 2011 | 08:19 PM
joshofalltrades's Avatar
joshofalltrades
for where to get one, pick up your phone, call the napa you talked to, and ask the important question "when can you have it here for me?" most parts you need that aren't in stock can be had in not more than a day, but a few have to be ordered in from the manufacturer, and can take up to a week, possibly with small shipping charges added.
or you can gamble by shopping online, appearing to save money, but either getting wrong parts or parts that fail in 2 weeks, and then having to fight everything again
Old Dec 13, 2011 | 08:30 PM
greywynd's Avatar
greywynd
I think the tach sensor might be a dealer only item. Did you find a fuse panel diagram? If not I can likely get one on here in a day or so for ya.
Old Dec 13, 2011 | 08:43 PM
tecgod13's Avatar
tecgod13
X2
the tach sensor can be hard to find, its not something autoparts stores will have, try a Ford dealer, maybe an IH dealer. There may be a few places on line as well.
Old Dec 14, 2011 | 11:58 AM
1949 F6's Avatar
1949 F6
Ok Ill check the dealer. Yeah still in need of the fuse panel diagram, that would be awesome!
Old Dec 14, 2011 | 03:58 PM
fonefiddy's Avatar
fonefiddy
There's a Guy here that can get Motorcraft parts for Ya, He usually beats the dealership prices.
partsguyed???
rhkcommander959
21
Jan 10, 2012 08:34 PM
1949 F6
Dec 11, 2011 04:42 PM
old ugly
Large Truck
Mar 19, 2011 11:10 PM
wreckinball
Feb 10, 2011 11:03 AM
Njsporty
13
Dec 16, 2004 09:25 PM
