i know there are some posts out on this i found it once but i am havin trouble finding it im wanting to know how to wire it in anyone got pictures need some help
I would suggest only using a DP Tuner decel tune or a Banks brake. They are the only ones I know that have the correct tuning in the trans so you dont burn it up. If you just make a switch you will en duo hurting your trans in the long run.
Dude I have a 6 speed manual I want a switch I don't want a dp I love my ts
Are you sure you love that TS chip?
(From another thread)
Originally Posted by dmanshane
if i have my chip on 140 extreme at 65 and put her to the floor by the time she reaches 104 mph at 25 psi boost shes runin 1500 at the back of the left manifold but when im pullin i can barely run chip on the 50 setting i know 7.3 are known to have higher egts than like a cummins how do i get it down to a safe so i can pull heavier harder and on like 75 or 100 setting ???
