custom window switch
Old Dec 10, 2011 | 08:57 PM
fordtough81's Avatar
fordtough81
Im having a problem with my power windows because the motor only goed on way. If i wire the red and yellow wire to a three way toggle and to a power source will the window gp up and down
Old Dec 10, 2011 | 10:02 PM
Gary Lewis's Avatar
Gary Lewis
I'm sorry, but I can't decipher that and I can't help if I don't understand. Could you try again?
Old Dec 10, 2011 | 10:18 PM
ctubutis's Avatar
ctubutis
No need to apologize, Gary; if you can't read what is written, or don't want to deal with all lower (or upper) case lettering and no punctuation & capitalization that looks like it's written by a 3rd grader, just ignore the post.
You can even put the OP on your Ignore list so you never heave to see anything from them ever again.
Works pour moi.
This is a Truck Technical Forum, not FaceBook or Twitter or SMS messages on a phone.
Old Dec 10, 2011 | 10:30 PM
billt28's Avatar
billt28
Only one way to find out, try it and see.
Old Dec 10, 2011 | 11:00 PM
fordtough81
I thought this was a ford truck forum, not an english class. I'm sorry for my typos. I had an idea on how to fix my window motor without following every wire in the harness, I did not need a grammar lesson.
Old Dec 10, 2011 | 11:42 PM
ctubutis's Avatar
ctubutis
Thank you for using good English, it's LOTS easier to read!
I'm hoping you're learning that how you present yourself out here has an awful lot to do with both the quality & quantity of help you'll receive, and you certainly DID need a grammar lesson.
The English classes one goes through in school are to prepare one for communicating effectively in the real world.
The harder it is for somebody to figure out what is being said, the lower the chances of your receiving good & useful information in replies.
How you present yourself & write is the ONLY method people have of forming an opinion about you and your intelligence.
And, if a person writes in an incomprehensible, illiterate manner, the assumption becomes, "This person isn't capable of understanding the answer, so why bother."
"If they don't care enough to write in a legible, easy-to-read, clear & accurate manner that helps me understand their problem, why should I go through the work of trying to help them?"
There are several really good & knowledgeable people out here (some of whom have factory wiring diagrams), why turn away their potential help by writing like a child and repelling them?
You might edit your original post (or make a new one) with some basic information - year of truck, model, etc. - and more clearly describe what the symptoms are and what your proposed idea is.
Old Dec 11, 2011 | 03:32 AM
81ChopTop's Avatar
81ChopTop
I'll take a stab here. You are thinking the switch is bad so you want to wire in a new one?
You could, but you need a DPDT on-off-on switch. Or you could order a new switch through LMC or find one in a scrapyard.
Old Dec 11, 2011 | 07:05 AM
Franklin2's Avatar
Franklin2
Here's how to do it. You need a DPDT Center OFF switch(Double pole, Double throw). Also make sure it's spring return to the middle(off) position.
Old Dec 11, 2011 | 07:48 AM
Gary Lewis's Avatar
Gary Lewis
But, before you do that you might want to figure out for sure that it is a switch problem. Jumper around the current switch to see if it might be a wiring problem.
randomhero1172
Aug 2, 2008 09:21 PM
NL544
Feb 6, 2007 10:49 PM
WheredaFoxhat
Dec 24, 2005 07:14 AM
ScottVP
Electrical Systems/Wiring
Apr 14, 2003 02:42 PM
