coolant question
Old Dec 12, 2011 | 08:39 AM
Liquid10Rider's Avatar
Liquid10Rider
Well guys I finally tracked concentrate Chevron delo from my local Prime Lube dealer. The best part is my shop is getting an oil delivery this week and they will deliver it with our normal guy.
Thanks for all the help, now I cant wait to do this flush and get it done with.
-AJ
Old Dec 12, 2011 | 01:07 PM
Stewart_H's Avatar
Stewart_H
-AJ
AJ, when you're ready, check out my "How To" thread here.
Gooch's Backflush & Coolant Information Thread - FTE
It's Gooch's backflush instructional, reprinted with his permission, along with his ELC coolant info. I've also added to the ELC info that I've learned after more research the past year and a half.
Stewart
Old Dec 12, 2011 | 01:15 PM
nlemerise's Avatar
nlemerise
Originally Posted by PaysonPSD
ELC can save time & money. The extra cost of ELC is easily recovered and can save money in the long run. Most likely the last time you ever have to do a coolant flush and fill. No need to use SCAs so no test strips or testing. No need for a coolant filter. Water pump lasts longer without SCAs. Much less chance of cavitation erosion. There is a reason that truck fleets use it.
Now this is GOOD advice except change the word "can" to the word WILL in sentences #1 and #2. The reason I say this is that truck fleets use it because it WILL save money (time is money too) and yields better protection for engines, though I still believe in a coolant filter (we have them on all the diesel trucks).
Old Dec 12, 2011 | 02:25 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by nlemerise
... and yields better protection for engines
Yep. Advantages to a heavy duty OAT ELC are present in the form of better cavitation and corrosion protection, particularly as time wears on, when other lesser coolants like the H-OAT (the Zerex G-05 and Ford Gold coolants are Hybrid OAT coolants) and conventional "green" coolants must be flushed.
OAT ELC has better heat transfer, less maintenance, longer life, and proven heavy duty use that meet the most strict standards in the industry are others.
Stewart
High76boy
Jun 8, 2014 12:46 AM
FSJ-EARL
Oct 29, 2010 08:08 PM
ngng
Mar 19, 2009 02:31 PM
D8chumley
Sep 3, 2008 09:29 PM
unluckylow
Jul 25, 2005 08:59 PM
