Im trying to put my 6 pos chip in and maybe its just me but im lost trying to follow these instructions. Seems like some steps are skipped. I have the pcm out and now it says to removve the parking brake assembly to give me room to access the switch assembly then put the pcm back in....doesnt say anything about running the switch anywhere and doesnt say how. Im kind of lost.
Best thing to do is pull the brake. Put the chip in with switch and run a piece of duck tape across the back. Then feed the switch assembly through as you put the pcm back in. After the pcm is back in put the brake back on and make sure not to pinch the wire. Mount the switch and your good to go.
Yes to the above but the first step of taking out the PCM is to clean the contacts but don't over clean them!
The guy before me used a crappy banks chip and he cleaned tge contacts down to where you can see copper.....it fit nicely tho, not lose at all. Will that be a problem?
Got it in today and WOW! What a difference. The go pedals a bit more touchy but thats ok. Ill just relearn. It smokes in all 6 tunes, guess 80 hp daily driver was a bad idea lol. But i cant complain!
Its amazing the difference. Its like dragging the PSD out of bed and kicking it in the butt!
I've got two chips now, if one needs reburned I'll put the other in.
