Chip extension cord
Old May 7, 2014 | 04:20 PM
tiopet's Avatar
tiopet
Chip extension cord
I would like to move my chip to a more reachable position.
Sometimes I need to remove the chip, so an extension cord of some sorts would be nice to have.
Instead of popping the hood and wrenching it out everytime.
What is the name of the male and female connectors needed?
Tried google for J3, 15 pin circuitboard connector, and more. But nothing
Old May 7, 2014 | 08:25 PM
fordpride's Avatar
fordpride
I don't know of any kind of extension cord.
It's a j3 port
To remove the chip all you have to do is remove the parking brake assembly and pull the chip. Ten mins. tops
Old May 7, 2014 | 10:26 PM
oldbird1965's Avatar
oldbird1965
Now that I've done it a hundred times (not really), I agree with Mike, ten minutes!
Old May 8, 2014 | 01:05 AM
Leemakesmepee's Avatar
Leemakesmepee
The only longer cord type ive seen is the switch that you can mount into a gauge pod. if i recall its longer than the wire and switch most the chips come with, but i may be wrong.
Old May 8, 2014 | 01:23 AM
tiopet's Avatar
tiopet
It's a Van, and it takes longer than 10 minutes
PCM is located in firewall above accelerator pedal. Access is from engine side, on left side of brake master cylinder.
But I need help of an extra person to hold the nuts inside the van, when i loosen/fasten the bolts from the engine side
If i could get the male and female connectors, i could use a flat ribbon cable as extension cord.
Old May 9, 2014 | 11:01 AM
DanielT28's Avatar
DanielT28
Ts6 that I have is pretty long. It's mounted directly under the steering column. No problems. Don't know of any extension.
Old May 10, 2014 | 08:05 AM
Talyn's Avatar
Talyn
Sounds like you need to have a stock tune burned onto your chip to correct this issue.
Old May 10, 2014 | 08:57 AM
tiopet's Avatar
tiopet
My chip is a fixed, baked in plastic thing with gold metal cap.
No switch. 100 Hp all the time.
At the moment i'm running without it, and overtaking is no longer an option
These burned things with a 6 position switch, can they be switched on the fly?
Old May 10, 2014 | 09:15 AM
oldbird1965
Yes.......
Old May 10, 2014 | 09:22 AM
tiopet's Avatar
tiopet
Thank you.
Old May 10, 2014 | 11:23 AM
BBslider001's Avatar
BBslider001
Are these really difficult to install? I am good with straight mechanical stuff, but electrical always freaks me out. I am looking at getting one pretty soon. Thanks!
Old May 10, 2014 | 02:28 PM
Talyn's Avatar
Talyn
oooooh, you have one of the old superchips.
Old May 10, 2014 | 03:16 PM
oldbird1965
Not hard at all Byron, #1 thing is don't rub off the silver coating on the PCM contacts, just the plastic coating. Don't ask me how I know this! LOL
Crewcab Turbo
Aug 31, 2012 08:58 PM
lazerf250
Oct 5, 2007 12:51 PM
DerrickC
Computer Chips & Tuners
Aug 22, 2004 09:04 PM
RustyWallace
Nov 16, 2003 11:24 AM
Intillzah
Sep 3, 2003 09:44 AM
