351 vacuum routing?
Old Dec 9, 2011 | 09:20 AM
bigtex45's Avatar
bigtex45
351 vacuum routing?
i have a 351 windsor all super up that's the way i bought it but it looks like this thing was just made to drag. no vacuum lines except pcv are hooked up. no canister to be found and vacuum advance not hooked up.
sooo.. what do i need its on a 67 so its emesions exempt. i defiantly want to hook up my advance but what do i do about my canister and where do all these hoses go on a edelbrock 4 barrlell.
Old Dec 9, 2011 | 12:18 PM
rustywheel68's Avatar
rustywheel68
shouldn't be much that you need to do-
i don't think a vacuum can would be necessary unless you have a big cam, and needed the additional vacuum to handle power brakes.
find a diagram for the Edelbrock carb- you should just need one vacuum line from the proper port (ported vacuum) on the carb to the vacuum advance. some people use full manifold vacuum for this, but i'm not planning on starting that argument up.
if you've got an auto tranny, you may need another line (full manifold vacuum) down to the vacuum modulator on the transmission.
Old Dec 9, 2011 | 12:26 PM
Rogue_Wulff's Avatar
Rogue_Wulff
On most Edelbrock carbs, the "ported" vacuum is the port that is on the front of the carb, towards the passenger side. That should be the one for a vacuum advance.
As mentioned, unless you have an auto trans and/or power brakes, there shouldn't be much need for any other vacuum lines on a 67 (assuming it's a truck, as that's what this section is dedicated to). Power brakes would hook into the port on the rear of the carb, and auto trans modulator would hook to the other small port on the front, towards the drivers side.
Old Dec 12, 2011 | 02:19 PM
bigtex45's Avatar
bigtex45
thanks guys im gonna forget the can and rote the advance to that timed port.
not sure if it has cams though i bought the truck as is and got lucky that after a fe gaskets and freeze plugs and a battery she started right up.a freind i worked with found me the truck , said fixing on it would keep me out of trouble.
havent accually drove it yet but man its loud and scary soundin.
o btw do i just plug up open vacum lines??
Old Dec 12, 2011 | 02:55 PM
rustywheel68
yes, just plug them.
but out of curiosity...where do they go?
Old Dec 13, 2011 | 09:12 AM
bigtex45's Avatar
bigtex45
so the big port up front is pcv and thats all thats hooked up,the big port on the side next to the fuel is wide open.could open ports lead me to lose vacumm and make my tranny shift rough ? i got a little bit of that going on too.
Old Dec 13, 2011 | 09:31 AM
bigtex45's Avatar
bigtex45
so yea the transmission modulator line goes to the full vacuum on the manifold
this 2 hose attachment thing with one side open. i bet if i plug that up my tranny will work better as well.
thanks you guys rock!
hoof
Feb 18, 2008 04:19 PM
Melchiah
Oct 24, 2005 06:58 AM
lectricman
Jun 26, 2005 01:16 PM
youngguy
Mar 15, 2004 08:07 PM
ions664x4
Apr 29, 2002 07:51 PM
