Radiator
Old Dec 9, 2011 | 05:55 AM
Redonkulous BOB's Avatar
Redonkulous BOB
Radiator
Just finishe up a rebuild on the trucks engine. Put in a new rad, just wondering of full to fill it or how the process goes. Right now there's about 2.5 Litres in it, do I fill the rest with distilled water? If so, how much. Radiator is the largest you can buy for truck and brand name is specter or spectrum premium.
Old Dec 9, 2011 | 07:14 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Unless you are going to flush it again don't forget the anti-freeze and rust inhibitor/water lubricant won't hurt. I've used distilled water before but personally didn't see any real benefit; depends on your water quality I oppose.
Old Dec 9, 2011 | 09:25 AM
Redonkulous BOB
Sorry my bad I meant to say there is already 2.5 litres of antifreeze already in the system. So question is still the same do I fill the rest with water?
Old Dec 9, 2011 | 10:07 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Yes. The wait for it to purge the air out of the system if you can. Otherwise bring it up to temp so the thermostat opens ant top it off.
Old Dec 9, 2011 | 11:49 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Also, these trucks don't have a coolant recovery system, so if you fill it full to the filler neck when it's cold, once it warms up you'll see coolant running out the overflow as the coolant warms and expands.
When the truck cools down the coolant contracts it will suck air back in.
When you check the coolant cold it should be about an inch or so below the filler neck, this is normal.
Old Dec 9, 2011 | 12:57 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Unless you live a rather warm climate, you need to have around a 50/50 mixture of water and antifreeze. Even in warm climates, this is still a good idea, as it helps prevent rust inside the cooling system.
I seriously doubt 2.5L is enough antifreeze to fulfill the 50/50 mix.
Old Dec 9, 2011 | 03:57 PM
Redonkulous BOB
Ok so I'll put about another 2.5L in it and fill it with water. Once done I'll let it run and go to temp. then go from there. Do I leave the overflow tank empty when I fill it up and just let t naturally fill or whatever? Thanks for the help guys!!
Old Dec 9, 2011 | 06:44 PM
Blue and White's Avatar
Blue and White
I just put the high capacity "Spectra Premium" in a '78 with 400M. I had flushed the block out with distilled water and it still had some water left in it that doesn't drain.
For filling, I looked up cooling system capacity first - 18 or 19 quarts on mine with "heavy duty" cooling. For 50/50 mix or better, I filled first with 2 1/2 gallons (10 quarts) of full strength anti-freeze then topped off with distilled water. It takes a while to make the initial fill as air needs to escape from the block.
Then I started it with cap off that helped burp some more air out. I topped it off, put the cap on and took it for a drive to get it up to temp with heater set on high. The first drive will burp some more air out. When cool, I topped again with distilled water - about 1" below the fill neck on the radiator - and called it good.
From now on, any coolant I add will be 50/50.
Fordman
Jun 1, 2004 08:39 PM
f100guy
Apr 3, 2004 08:52 PM
Charlotte
1983 - 2012 Ranger & B-Series
13
Jan 26, 2004 07:22 PM
Krzysiek4x4
Oct 3, 2002 06:18 PM
