Help w/ some codes please...........
Old Dec 8, 2011 | 04:58 PM
dan.alger's Avatar
dan.alger
First I would like to say you guys are awesome for helping us fellow FTE users......Thanks in advance...........I was updateing my programmer via the internet and reprogammed truck, after about a 3 mile trip checked for codes....... 3 came up, can you help me with what they are?
1) P132B
2) P1000
3) U0306
what do these mean????????
Old Dec 8, 2011 | 05:31 PM
SixGunCaliforniaKid's Avatar
SixGunCaliforniaKid
check the tech folder
the short cut to the codes is http://www.dieseltalk.com/support/DTC.pdf
based on the codes it has to do with the FICM check it first as it is probably causing atleast 2 of those codes above. theres a how to in the tech folder also...
Old Dec 8, 2011 | 05:33 PM
SixGunCaliforniaKid
sorry I cant be of much more help on the FICM but I havent had the pleasure of playing with one.. (knock on wood)
Old Dec 8, 2011 | 05:47 PM
cheezit's Avatar
cheezit
P132B UNDERBOOST
P1000 pass but not all moniters ran
u306 vid block id error.. or something of the like. basicly softwere fault from a programer.
Rusty Axlerod's Avatar
Rusty Axlerod
P132b-Turbo boost control "A" electrical.
P1000- OBD systems readiness test not complete.
U0306- Software incompatibility with Fuel Injection Control Module.
Old Dec 8, 2011 | 07:10 PM
BLADE35's Avatar
BLADE35
the good old P132b this one can be a PIA
read thru this thread
code p132B
https://www.ford-trucks.com/forums/1...405-p132b.html
Old Dec 8, 2011 | 07:12 PM
bismic's Avatar
bismic
P132B is a code related to the calibration from the recall 06E17 (part of the Inferred EBP strategy). It means that there is a problem with the VGT system. P132B is a fault code that is set if the required boost levels are not achieved during a learn cycle or at specific speed fuel demand points. This code indicates that there are issues with the turbocharger, MAF sensor, MAP sensor/hose, IAT2 sensor, intake leaks, or exhaust leaks, etc. Frequently it is a sticking turbo issue. This code can also throw a P0401 EGR code.
oops - you beat me Benny
NinthGenF-SeriesOBS
Mar 24, 2016 04:03 PM
Dans2Fords
Feb 24, 2012 12:25 AM
joe blow
May 19, 2011 06:53 PM
David1990
May 26, 2006 09:15 PM
choppersinc
1983 - 2012 Ranger & B-Series
Mar 1, 2005 08:29 PM
