HELP
Old Dec 8, 2011 | 09:29 AM
HE11boy400's Avatar
HE11boy400
HELP
i have a 1993 f250 7.3 idi. tried to start it today and got no wait to start light. this is not unusual for my truck may take a few times it get the light to come on and the glow plugs to fire. but this time it never fired, after 15 min and god knows how many tries i gave up. not wanting to make anything worse i go to you all for help. need step bye step advice new to diesel power.
<!-- / message -->
<!-- controls -->
Old Dec 8, 2011 | 09:39 AM
snaponprofile's Avatar
snaponprofile
Check your glow plug relay, seems like it might not be opening. The trouble shooting thread is a sticky at the top of the forum page.
Old Dec 8, 2011 | 09:59 AM
joe f350's Avatar
joe f350
did u try start fuild any pools of fuel on the motor and do u have a black heater
Old Dec 8, 2011 | 10:12 AM
snaponprofile
No WTS light usually signals something wrong with relay. Unless you are in -0 temps, you shouldn't need a block heater.
Old Dec 8, 2011 | 10:28 AM
joe f350's Avatar
joe f350
yea i was gona to tell him to plug it in if he had one see if it helps it start
Old Dec 8, 2011 | 12:38 PM
HE11boy400's Avatar
HE11boy400
its turning over fine it has something to do with the plugs. its in the 40s here. i am new to this forum what is the sticky?
Old Dec 8, 2011 | 04:32 PM
farmert's Avatar
farmert
The sticky is the first 2 or 3 threads at the top of the page with the READ FIRST in red. They never move.
Old Dec 8, 2011 | 07:44 PM
IDIDieselJohn's Avatar
IDIDieselJohn
It should have started eventually even without plugs in 40's temps....
CAUTION:
DO NOT crank more than 20 seconds at a time, and give a full 2min cool down time to the starter before cranking again....
Starters aren't cheap on these!
Old Dec 8, 2011 | 08:03 PM
starmilt's Avatar
starmilt
I have seen these things not start without plugs on a 90 degree day. lol
Old Dec 8, 2011 | 08:10 PM
IDIDieselJohn
I hope your kidding star...... that's sad if true.
Both my IDI's have started in the 40-50's temps without plugs, one was the camper when it had 3 bad plugs, and the controller was only coming on for 1 second, and even the 7.3 eventually started when it to has bad plugs and light wasn't coming on.
Guess they got good compression
Old Dec 8, 2011 | 08:19 PM
mechmagcn's Avatar
mechmagcn
That would be the 7.3 in my 94 F250 but the 6.9 in my 83 F250 4X4 will start just about anytime without glow plugs When I checked them last week, only one appears to be good and two have the connectors rusted off.
Old Dec 9, 2011 | 11:27 AM
HE11boy400's Avatar
HE11boy400
didnt want to over crank it i know if u do it can be very damaging to the motor. better safe then sorry.
Old Dec 9, 2011 | 04:01 PM
LSO1123's Avatar
LSO1123
I agree, if all else was working properly it should have started even with no glowplugs. How are your batteries? Cooler temps can drain old batteries and your batteries need to be good to crank these motors over fast enough. If your batteries are good check to make sure you're getting fuel to the injectors.
Old Dec 9, 2011 | 07:50 PM
airkewld4life's Avatar
airkewld4life
My "Wait to Start" light stopped coming on and it ended up being my glow plug controller.
Old Dec 10, 2011 | 07:35 AM
bashby's Avatar
bashby
No damage will be caused to the engine from excessive cranking, but the starter needs abour 2 minutes cool down time between 20 seconds of cranking.
